Fuel tank replacement with a plastic one?
Old Nov 16, 2009 | 09:30 AM
PhiL4x4's Avatar
PhiL4x4 is on a distinguished road
Default Fuel tank replacement with a plastic one?
Hi,
I got a 96 Blazer 4dr, the tanks is leaking there a pinhole and it's seem pretty rusty and i need to change the tank. I know that some newer model are using plastic tank instead of the old metal one... Is it a direct fit? or they changed the shape and connector location?
Thanks
Phil
Old Nov 16, 2009 | 12:24 PM
Off the top of my head, I would say you would end up changing fuel pump assemblies at the same time if you were to undertake such a conversion. Wiring, plumbing, etc will likely be different to do so. The fuel tank part numbers change between 97 and 98 with the available steel tanks. I believe 98 was the first year for the plastic tank (it is the first year that shows up stating "w/o plastic tank" for the 4-door tanks).
Things look like they are still located near the same spot, but again, without seeing them side by side...
Old Nov 16, 2009 | 12:48 PM
PhiL4x4's Avatar
Thanks for the info. I think I will go with an new aftermarket one... i dont have time to search and compare both tank. I just had time to fix it with the old trick of the soap bar lol. I need to change that today.
Thanks
PHil
Old Nov 16, 2009 | 04:05 PM
degaine_designs's Avatar
degaine_designs is on a distinguished road
I had the same problem with my '89. I found a plastic tank on eBay that was a direct fit, but I think its a bit taller, which would make sense as its a 20 gal tank as opposed to the stock 13 gallon. The stock straps didn't fit, so I bought longer bolts, problem solved. I installed a new pump because mine wasn't working properly. It all worked together fine.
nbguide
Jun 7, 2013 04:39 PM
bob_351c
Oct 30, 2011 10:55 PM
ryito1122334455
Aug 1, 2011 04:36 PM
Bumbalawski
Aug 4, 2010 05:56 PM
degaine_designs
Aug 20, 2009 08:15 AM
