Fuse pin replacement
Old Apr 5, 2011 | 10:35 AM
kooldub's Avatar
kooldub is on a distinguished road
Default Fuse pin replacement
good day! my son has a 01 s10 blazer and the passenger power window isn't rolling down. looks like "pin" where the fuse plugs into is broke. how can i replace that? it's for the fuse in the engine compartment... much thanks!!
kris
Old Apr 5, 2011 | 10:43 AM
I cannot recall anyone successfully dismantling the fuse/relay center to repair damaged terminals... Most have purchased the complete fuse/relay center from a junkyard and installed it. There are two different versions (standard & up-level) so you have to make sure that the replacement has the same terminals in all of the same location as yours does.
Old Apr 5, 2011 | 10:59 AM
kooldub's Avatar
that doesn't sound fun. so when you say fuse/relay center, you saying the whole "panel" that all the fuses plug into? i assume i can tell the differences visually? is it a straight swap, unplug "some" connectors and install? is this common that those terminals break? much thanks!
kris
also, how much should i expect to pay for the fuse panel used? i found one locally for $50, seems high... thanks peeps...
Last edited by swartlkk; Apr 5, 2011 at 12:26 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Apr 5, 2011 | 12:29 PM
$50 seems right for the fuse box. You can tell visually. All of the holes are there, but not all will have the metal terminals in them. You must make sure that all of the terminals are in same locations as your box has them.
Jhowey
17
Apr 7, 2012 04:50 PM
SLE_MuNkY
Nov 21, 2011 09:31 PM
step66
Jul 23, 2010 12:20 PM
step66
Mar 27, 2010 01:06 PM
Spectreblazer
Jan 31, 2010 12:43 AM
