Fuses
Old Jul 23, 2007 | 11:56 PM
metalheadgoalie's Avatar
metalheadgoalie is an unknown quantity at this point
Default Fuses
Anyone have a layout or something of the fuses? I am trying to find where the fuse is for a 1999 GMC Envoy with an air compressor in the back. I waslooking atmy envoyand I noticed that I had this switch in the back and found out it was an air compressor for like the tires or a ball. The dealership said it was more than likely a blown fuse but it would cost 40 to find it.
Old Jul 24, 2007 | 07:47 AM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
Default RE: Fuses
Don't know about the Envoy's but my Blazer has all the fuses identified right on the fuse cover plate itself. Did you look there? You could also check the owners manual that should be in the glove box, that usually has a fuse layout and description of each.
Old Jul 24, 2007 | 07:54 AM
Default RE: Fuses
There is a relay located on the back side of the rear passenger side trim. You have to remove the trim to get to it.
The fuse for the auto-level system is labelled 'LD LEV' in the underhood fuse box. It'll be the 25A fuse next to the Starter Fuse.
Also, here is a schematic for you:
*click on the thumbnail to view the full image*
Old Jul 24, 2007 | 01:45 PM
Default RE: Fuses
i replaced the fuse but it still isnt working
Old Jul 24, 2007 | 02:26 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: Fuses
ORIGINAL: swartlkk
Then you probably need to replace the relay above with a new one. I would take the old one out and then go to advance auto parts or NAPA or some carparts store and see if they have a replacement in stock. Just remember to right down the way you pulled the relay out so that the correct pins are put back in the correct holes.
-Lenny
Old Jul 24, 2007 | 06:41 PM
Default RE: Fuses
Is it this part of the trim behind the air compresser unit itself? or elsewhere and if its somewhere else could u show me a pic, haha sorry im not very experienced.... and i keep trying to fix the size of the image so im sorry if its huge still
Old Jul 24, 2007 | 06:48 PM
Default RE: Fuses
If that is the rear trim panel on the passenger side, then it should be behind that trim panel from my understanding.
-Lenny
Old Jul 24, 2007 | 07:18 PM
Default RE: Fuses
Here ya go:
It'll be located directly behind the panel where your screw driver is. You can jumper the relay and see if it turns on the air compressor by jumpering the cavities that correspond with pins 30 & 87.
You may also want to check the IGN E fuse (10A) in the underhood fuse block, however this fuse also powers the A/C Compressor Relay... That powers the relay for the compressor, the 'LD LEV' fuse powers the timer which I think is part of the control module.
Old Jul 24, 2007 | 08:45 PM
Default RE: Fuses
its not the IGN E fuse i just checked on it right now. For the trim in the back thou, how do you take it out w/o breaking any of the tabs or whatever is holding it. In that pic above I kinda bent the tabs to get it open
Old Jul 31, 2007 | 07:21 PM
Default RE: Fuses
so i took it in to get a free diagnostic and they say it is the pump itself? Could it be? cuz so far no one, even the dealership, has mentioned it could be that
