G80 Axle Shafts
Old Nov 24, 2013 | 08:09 AM
Tsunamipete's Avatar
Tsunamipete is on a distinguished road
Default G80 Axle Shafts
I have a 1996 2dr 4wd 5 speed blazer with the G80 diff. , I have looked without any results on a part number for a replacement axle shaft, the passenger side is toast where the bearing rides on, I went to the junk yard yesterday only to find out that my axle is a larger diameter than the axles on the other blazers that were there, does anyone know where to buy or have a part number for the G80 axle shafts, any help would be great!!!
Old Nov 24, 2013 | 09:27 AM
rriddle3's Avatar
Go to GM Parts Direct, click the 'catalog' tab and choose your vehicle, then click the link for 'Universals & Rear Axle'. You want to go to page 8 to find the 4WD shafts.
Old Nov 24, 2013 | 11:06 AM
Thanks for the reply, i am assuming that this axle shaft has 30 spline count, I could not find anywhere on there that it was? the axle shaft that I removed is 29 1/8" in length.
Old Nov 24, 2013 | 01:11 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
When I g80'd my old crew cab I used the stock open diff axles.
Old Nov 24, 2013 | 02:14 PM
One of them might be a ZR2, (higher, wider package). Seems to me ZR2 axles are about 1" longer. Did you look into the possibilities of a repair bearing? WAY cheaper than an axle. The repair bearing rides on the axle in a slightly different location and allows you to use the original axle.
Buy National Axle Repair Bearing RP-6408 at Advance Auto Parts
Buy National Axle Repair Bearing RP-5707 at Advance Auto Parts
Old Nov 24, 2013 | 02:33 PM
looks like that would work well, have you installed one before?
Old Nov 24, 2013 | 02:36 PM
One??? Nope, several
Old Nov 24, 2013 | 02:41 PM
I am ordering 2 now , trying to get them shipped over night , thanks for your help
Old Nov 24, 2013 | 02:45 PM
Two different sizes: measure twice, order once Most auto parts stores carry them in stock, might be worth a call to your local store and save on shipping costs.
Old Nov 24, 2013 | 03:13 PM
found them here locally!! thanks
