G80 Rear Differential
Old Mar 30, 2011 | 11:06 AM
I couldn't remember where the split happened in gearing and didn't have the time to look up the thread where Gary went through it a year or so ago. Knew someone else would know for sure.
Old Mar 30, 2011 | 07:00 PM
racsan's Avatar
racsan is on a distinguished road
oh yeah, i would swap the whole assemblies out. i dont have the tools or experiance for differential setup. (backlash,pattern,ect) the only issue i may have is with the front, the parts truck has "flanged" axles, the good truck has the c.v. shafts that just simply "plug-in" to the differential. should still interchange, both are gen2's i'll just put some new axleshaft seals,oil and brakes on my "3.73" axle this spring/summer and have it ready for if i need it. probly wouldnt take 2 hours to swap whole axle assemblies in the rear. the front however---iknow i'll want a whole afternoon. thats how long it took to pull the one out of the parts truck. it would be cool if the G80 is still functional. i have my doubts with the age/milage on it.
Old Jun 7, 2011 | 12:42 AM
MikeRo's Avatar
MikeRo is on a distinguished road
I may not have followed if it was said before but can you just swap out the whole rear axle. Currently i have a open diff on my blazer (don't remember which gear ratio) if i were to locate a G80 in a blazer rear in a junkyard (probably unlikely but i can try) is it possible to just swap them out? Would there be an issue with the different ratios in the front and rear? Just an idea i had, wanted to be sure that two blazer rears are interchangeable before i even considered it.
Thanks
Old Jun 7, 2011 | 12:46 AM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
never mix ratios from front to rear
-OSS
Old Jun 7, 2011 | 01:08 AM
MikeRo's Avatar
That's what i thought but i wanted to be 100% sure. So i would have to find matching front and rear diffs presumably from a Zr2......That alone will take me years wandering among the junkyards, plenty of time to learn.Thanks
Drew4711
Oct 6, 2012 12:47 PM
paroh7
May 23, 2010 08:33 AM
96Blazernut
35
Mar 8, 2010 07:30 PM
Calgary ZR2
17
Jan 16, 2009 05:22 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
