gas gauge >:|
Old Mar 1, 2013 | 05:40 PM
swanman35's Avatar
swanman35 is on a distinguished road
Default gas gauge >:|
Well since I bought my loved blazer the gas gauge hasn't worked. It would either be on full or empty. Recently I've noticed it has been fluctuating around, and right now I think the gauge has actually been working. I put fuel injector cleaner in a few weeks ago. I'm nkt sure if that has anything to do with it. I think its a wiring problem but I know blazer have this as a common problem. Any thoughts as to what it could be?
Old Mar 1, 2013 | 05:56 PM
mr.vls's Avatar
The fuel sending unit is most likely the cause.
Old Mar 1, 2013 | 06:03 PM
Twip's Avatar
either that ^^ or possibly a ground...
Old Mar 1, 2013 | 06:43 PM
Rumblur's Avatar
Rumblur is on a distinguished road
if your truck has 100k miles on it or more, just go ahead and buy a pump. You're going to replace it anyway sooner rather than later, and that will fix your gas gauge problem.
Old Mar 1, 2013 | 07:11 PM
swanman35's Avatar
Yeah, it has 108,xxx miles. I recently changed the LIM gasket,and since then my gauge has been working correctly. I'm not sure if those 2 are related.
Old Mar 1, 2013 | 09:23 PM
Strictly coincidence, they are not related. As mentioned, the fuel level sender is probably on its way out. If you unplug the module connector, the dash gage should indicate past full. If you ground the purple wire in the harness connector, the dash gage should indicate below empty. The level sender can be serviced separately but requires removal of the tank and fuel pump module. At 108K, if you drop the tank, you might as well replace the entire module. AC Delco or Delphi only
Old Mar 2, 2013 | 10:12 PM
swanman35's Avatar
Yeah, that's what I figured. Thanks a lot for the help everyone!
Old Apr 27, 2013 | 02:40 AM
chitown906's Avatar
chitown906 is on a distinguished road
I'm seeming to have the same issues with my blazer , but not the whole full or empty issues just the fluctuation . I fill up and drive under 20miles and it will be at a quarter of a tank if not a little less. The pump was just changed under a 2 months ago , and im guessing the sending unit was also replaced ? Can't seem to find any real info as to what tank size our 4dr's have I get 14-18 not really sure what to believe, just know that at every fill up I dont fill up past 14 gallons .
Chi_Town
Old Apr 27, 2013 | 07:44 PM
Spree's Avatar
Spree is on a distinguished road
Chi_Town
What year is it? My 98 has the metal 18 gallon tank. Some have a plastic tank (hold's a little less).
Old Apr 27, 2013 | 09:35 PM
cleburne red's Avatar
My '95 4 door also has an 18 gallon metal tank. The 2 door tanks are shaped differently, but I'm not sure it the capacity is different.
grayman63
Jul 17, 2013 01:56 PM
98blazerb
Jun 20, 2012 09:53 PM
hoppy26
Jan 26, 2012 02:08 PM
starandrose
Sep 22, 2010 06:25 PM
Mulisha
Mar 24, 2008 09:14 PM
