Gas leak in engine
Old 11-14-2011, 12:24 PM
elmcarter's Avatar
elmcarter is on a distinguished road
Default Gas leak in engine
I have a 2000 Chevy Blazer, 4.3L. It have a gas leak coming from the top of the engine. the leak is at the Fuel pressure regulator I have changed the "o" rings several times that doesn't work. I think it has a crack in the plastic part the lines go in to. How to fix this and what is the plastic piece called and is it sold separately?
Old 11-14-2011, 12:36 PM
*Moved to a new thread* - Please do not post a different question in someone else's thread. It is impolite and often pulls attention from the initial problem at hand. If a thread doesn't match up with your intended topic and searching has not turned up other threads on your topic, please create a new thread.
If your leak is caused by a crack in the injector housing, you will need to replace it. About the only source that I could find in a quick search would be a dealership. It is far more cost effective to replace the entire spider though. The upgraded MFI spider "kills 2 birds with one stone" as it would fix your leak and do away with the very often problematic poppet nozzles as found in the factory SCFI spider.
starandrose
09-22-2010 06:25 PM
trapperjohn4077
06-07-2010 10:49 AM
degaine_designs
08-19-2009 11:12 PM
N.alaska_blazer
02-23-2009 01:31 PM
SnowRemorse
01-04-2008 11:26 AM
Quick Reply: Gas leak in engine
