gas pick up problem
Old Sep 3, 2011 | 03:17 PM
krowkiller's Avatar
krowkiller is on a distinguished road
Default gas pick up problem
hello people i have 2000 blazer LS, and when i start off it makes a popping sounds. Don't pick up speed, unless i kinda pump the gas paddle and it happens sometimes if i try to pass or pick up speed. I put a new rotor button and cap on it also the plugs and wires r also new anyone know what it could be any help will be a help.
Old Sep 3, 2011 | 04:19 PM
pettyfog's Avatar
Originally Posted by krowkiller
hello peps i have 2000 blazer LS, and when i start off it makes a popping sounds. Don't pick up speed, unless i kinda pump the gas paddle and it happens sometimes if i try to pass or pick up speed. I put a new rotor button and cap on it also the plugs and wires r also new anyone know what it could be any help will be a help.
Is the check engine light on?
Kindly give us timeframes / sequence of events. Are all the new parts because of this problem or did problem occur after maintenance activity.
Degree and timeframes of worsening.. or popped up all at once and has been same since.
Old Sep 3, 2011 | 05:39 PM
krowkiller's Avatar
no the check engine light aint on and the plugs and wires were on it for about 6 to 7 months, just for a yearly thing i do and the problem only started about 4 or 5 weeks ago but that is y i changed the rotor button and cap do to the lack of responds and poping when u give her gas but made no difference.
Old Sep 3, 2011 | 05:47 PM
chris015's Avatar
Check fuel pressure with a fuel pressure gauge.
needs to be at 60 at key on,then leave the key on for 10 min. if it drops below 52ish then fuel regulator is bad,Could also be the pump too.
If its starving for fuel then it can cause the loss of power and popping.
Old Sep 5, 2011 | 08:51 PM
krowkiller's Avatar
the pump seems to be ok but i noticed a raw fuel smell from tail pipe on startup dont know if it is there when i move or let it idle for a bit. iam starting to thing it is fuel regulator, but the top of the motors r different on a 95 and 2000 so is the fuel regulator still hidden under the top of motor like a 95 or is it easy to get at and change.
Old Sep 5, 2011 | 10:14 PM
AJBert's Avatar
Sorry, not your peps, or rather more correctly, "peeps". Proper use of the English goes SO far with me, unless English is not your first language. Take offense or not, it will not bother me one way or the other.
Old Sep 6, 2011 | 10:37 AM
krowkiller's Avatar
i cant find the location of the fuel regulator any were on the internet so i took a pic of my motor so u know what moter it is it is a 4.3 V6 vortec
Old Sep 6, 2011 | 10:46 AM
The FPR (fuel pressure regulator) is attached to the back side of the fuel injection spider which is located inside intake manifold. To access it, the upper intake plenum (large plastic piece that the throttle body sits on) must be removed. A prerequisite to removing the plenum is removing the throttle body, fuel lines, various hoses/connections, etc.
Have you done the fuel pressure & leak down tests as inquired about above? If so, then what were your results? If not, get a gauge & perform the tests and it will show you whether you have a regulator issue, pump issue, etc.
Old Sep 6, 2011 | 10:52 AM
krowkiller's Avatar
http://i1184.photobucket.com/albums/...43V6vortec.jpg
in this pic is my motor 2000 4.3 V6 vortec does it have EFI, it looks like a throttle body to me. if so were would the fuel regulator be cause i have a 1995 4.3 V6 vortec and they r very different it has the the spider injectors under the top dome which i dont see on my 2000 this is y i am lost on were the fuel regulator is too can someone help me out thanks.
starandrose
Sep 22, 2010 06:25 PM
bigdaddykane93
Dec 6, 2009 05:28 PM
fjdavid
Aug 14, 2007 06:37 AM
nofear17bmx
Jan 4, 2007 10:52 PM
rooster
Dec 29, 2006 02:49 AM
