Gas tank fill problem 2002
Old Sep 28, 2008 | 07:51 AM
dgastone's Avatar
dgastone is an unknown quantity at this point
Default Gas tank fill problem 2002
Unable to fill tank without pump cutting off no matter how slow I try to pump the gas. The tank can be 1/4 full, cut offs start immediately. Fuel pump was replaced due to engine cut off problem back in 10/06. My kid was driving the car and complained about the fill problem but never got it back to the dealer. Any suggestions on what to look at would be appreciated. Thanks
Old Sep 28, 2008 | 08:56 AM
BGwood88's Avatar
BGwood88 is an unknown quantity at this point
Default RE: Gas tank fill problem 2002
My 03 blaze does the same just depends on whose pump it is
Old Sep 28, 2008 | 12:02 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
I just rec had the same prob, it turned out that the nozzle wasnt at the correct angle.. Sounds stupid but if ya look at most gas pumps it shows how the nozzle has to be in the tank to work properly..
Old Sep 28, 2008 | 12:51 PM
bad350v8s10tahoe's Avatar
bad350v8s10tahoe is an unknown quantity at this point
Same here on a 97 blazer and 85 bronco, could only fill at half pump speed. Never did figure it out [:@]
Old Sep 28, 2008 | 01:36 PM
I would inspect the fill pipe. It is possible that there is something in the vent tube or that the dealership hooked something up incorrectly.\
*EDIT* - *Moving to 2nd Gen Tech*
Old Sep 28, 2008 | 04:50 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
tank may not be venting properly or the fill tube may be pinched
Old Sep 29, 2008 | 10:32 AM
WolfPack's Avatar
Try filling up in the morning...less fumes.
Old Sep 29, 2008 | 12:00 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
ORIGINAL: packofqtips
My 01 does exactly the same thing. Have to HOLD the nozzle at the correct angle.
I guess the venting issue, could explain my PO440 EVAP code, too!
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
Debbie
Jan 27, 2010 07:42 AM
jsmz
Jan 25, 2010 11:30 AM
alowe
Jul 31, 2009 02:34 PM
