Gasket Removal
Old Dec 31, 2010 | 07:57 AM
kevinph's Avatar
kevinph is on a distinguished road
Default Gasket Removal
I am replacing the oil adapter gasket on a 98 blazer and cannot find a way to remove the old gasket material. A small portion of the old gasket is stuck to the engine. It is very hard and I cannot scrape it off with a gasket scraper, screwdriver or razor blade. Does anyone have a recommendation of something that will soften the gasket? Remember that it is on the bottom of the engine and hard to get to.
This gasket is very hard. On the adapter side I had to be careful scrapping it off because the aluminum was softer than the gasket.
Old Dec 31, 2010 | 08:20 AM
Camaro98's Avatar
Camaro98 is on a distinguished road
As long as the gasket is non-metallic (paper, cork, etc.), try getting at it with a wire wheel on a drill. Just make sure to clean the dust off of the area afterward.
Old Dec 31, 2010 | 08:51 AM
Soak it with acetone.
Old Jan 1, 2011 | 09:19 AM
kevinph's Avatar
Yep. I used one of those fiber disks (like sandpaper) on the end of a drill with a long extension.
limited edition 1
Jan 27, 2023 11:07 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
