gauge cluster
Old Oct 15, 2007 | 10:28 AM
blazinNva's Avatar
blazinNva is an unknown quantity at this point
Default gauge cluster
im new here so hi everyone. i've got a problem with my gauge cluster that has me confused and pissed. my OD and Shift Indicator do not have an indication of any kind. the RPM sticks at 1000 and the Speedo at 10MPH. does anybody have a clue, maybe seen this before, or point me in the right direction.
thanks
Old Oct 15, 2007 | 10:01 PM
muleman's Avatar
muleman is an unknown quantity at this point
Default RE: gauge cluster
have you had it out before....
Old Oct 15, 2007 | 10:18 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
I would say take it out and make sure you replug it in good and tight, otherwise your cluster may be bad and you will have to get a replacement. The other thing you could try, is to remove both the battery leads for like 15 minutes then hook it up again and see if that does anything, I think this is supposed to reset something, and what the heck, is something free to try that wont screw anything up. Just make sure you have the code for the stock radio if the little red LED flashes since the theftlock system is on (if flashing). This will lock the headunit if the feature is enabled and power is disconnected. Otherwise it will probably be $15 or less at the dealer to have them get it unlocked. After they unlock it they should give you a printoff with the code.
blazerguy09
Jan 7, 2015 03:26 PM
Lidberg
Aug 10, 2011 01:01 AM
3kidblazer
Feb 1, 2009 11:22 PM
offroadin974wd
Jan 22, 2007 10:37 PM
magtec
May 5, 2006 06:48 PM
