gauge gremlins
Old Jun 7, 2011 | 11:38 PM
98ls's Avatar
98ls is on a distinguished road
Default gauge gremlins
After installing a pioneer cd player in my 98 blazer the fuel gauge stopped working as did the temp gauge. the low fuel light stays on and the battery light remains on as well. any help would be appreciated
Old Jun 8, 2011 | 03:18 AM
Blazed&Confused's Avatar
Blazed&Confused is on a distinguished road
Did you use an adapter harness when installing the radio? If so, make sure you tape off the ends of any unused wires so they don't short out, and double check the harness for any pins that may have gotten bent when plugging it in. Also, check all of the fuses in the fuse box to make sure they are no blown. The 98 is a pretty staright forward radio installation and I don't see any reason why you would have this issue. I have been installing professionally for over 15 years, and have never ran into this.
Old Jun 8, 2011 | 09:44 AM
98ls's Avatar
thanks for the speedy reply. yes i used the adapter and actually checked for bent pins yesterday and checked all fuses with test light and all are fine. i have also changed the cluster out and still not working. I have tried all i know to try.
Old Jun 8, 2011 | 11:53 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
I would un-install the radio electrically and see if it corrects the problem. If it doesnt, then you need to find the failed/damaged part. If the guages wrk correctly, then you can recheck everything you did during the install.
If I goof something up (Or am not sure,) I try to go back to the original configuration.
Good Luck!
Old Jun 8, 2011 | 01:42 PM
98ls's Avatar
just tried that no difference in problem im a totally stumped. how hard would it be to wire up an autometer gauge for my fuel?
Old Jun 8, 2011 | 01:48 PM
Did you mess with any grounds in behind the dash?
Old Jun 8, 2011 | 02:10 PM
Rottidog's Avatar
Saw the issue & thought grounds right away too. After having the underhood fuse box out & it wouldn't get gas, light didn't work, fuel guage didn't work & a few other things it turned out to be the ground under the fuse box. It's the ground for all the relays, no wonder a lot got messed up. Even though they all tested OK for power there wasn't any ground for them to actuate.
They like to group closely placed things to common grounds.
Old Jun 8, 2011 | 03:11 PM
98ls's Avatar
figured out the source. four wheel drive fuse was not there plugged one in and everything started working again. i looked a couple days ago and thought the slot didnt have prongs in it but turns out it does and all that is wired into that fuse. after putting 10 amp fuse in fuel gauge works battery light went off and temp gauge working again thanks for all the help guys
Thor_449
Jul 24, 2008 08:05 PM
KaptainKen
Apr 2, 2008 06:01 AM
blkblazerLT
Mar 16, 2008 12:29 AM
brycemartin
Jul 25, 2007 11:41 PM
KIllarb634
Jun 3, 2007 11:58 AM
