HELP!!! Electrical Gremlins
Old May 27, 2007 | 11:27 PM
KIllarb634's Avatar
KIllarb634 is an unknown quantity at this point
Default HELP!!! Electrical Gremlins
Ok Problem Number one
Windshield Wipers Go haywire dont go off when i turn them off; I tried the COLD SOLDER fix and it DIDNT work.
Problem Two
D.R.L.'s won't shut off ever, Don't know how to fix it.
Number 3,
Power mirror switch doesn't work Probally broke. Is that normal and is there a fix for it, the switch itself or do i just need to find a new one?
Number 4
Radio Is cutting out at higher volumes. Checked grounds and they were good; even had the radio out and grounded to key and it did it and we all know thats a good ground.
Number 5
Fog Lights do not work; It seeming to me as if that whole switch is screwed up since i cant shut off the DRL's either.
Any and all Help is appreciated
Thanks in advance
Brian
Old May 28, 2007 | 09:25 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: HELP!!! Electrical Gremlins
correction #1 replace wiper pulse module
#2 Do the DRL's shut off when you manually turn on the headlights? If so I think they're working correctly, but make sure you don't have anything covering the ambient light sensor..in theright speaker grill on top of the dash.
#3If both mirrors are inoperative, either has a blown fuse (unlikely) or a bad switch.
#4 Sounds like a bad radio to me...
#5 It's very common for both fog light bulbs to go bad at very close to the same time, so I'd unplug one of the bulbs, put a test light in the connecto, and turn them on. If the test light lights, you have bad bulbs, if not, repost and I'll dig up a schematic and help ya diagnose them.
Old May 28, 2007 | 07:40 PM
KIllarb634's Avatar
What is the wiper pulse module
#2 The DRL's do shut off when i turn the headlights on, is there any way i can bypass them from turning on
#3Yes both mirrors are blown, is that a common problem with the blazers?
#4Yeah me too, but was hoping there could have been a gremlin or something stupid since i love the radio.
#5 I'll check the fogs with the VOM this week.
Thanks
Brian
Old Jun 3, 2007 | 11:58 AM
KIllarb634's Avatar
Fog Lights have no power new bulbs won't work either.
Thanks
Brian
tmoble
Apr 15, 2011 07:59 PM
Thor_449
Jul 24, 2008 08:05 PM
KaptainKen
Apr 2, 2008 06:01 AM
blkblazerLT
Mar 16, 2008 12:29 AM
brycemartin
Jul 25, 2007 11:41 PM
