Gear grinding type noise Need some help
Old Mar 17, 2014 | 11:13 PM
Heffty's Avatar
Heffty is an unknown quantity at this point
Default Gear grinding type noise Need some help
I am hearing a grinding gear kind of noise. Sounds like its up in the front. Occurs loudest when I decelerate and changes in pitch from high to low as the vehicle slows down. I can feel it vibrate on the floor. It's not affected in any way by my turning. When I press the gas the sound seems to lessen or perhaps disappear. When I drive in reverse there seems to be a clunking sound and the reverse motion is not smooth.
Any thoughts?...and with your thought can you suggest what I should pay a mechanic to have it fixed?
Thanks.
Old Mar 18, 2014 | 03:21 AM
DaveHearne's Avatar
DaveHearne is on a distinguished road
Could be any number of things but possibly easiest thing to check 1st are the driveshaft joints? If they start to break up they can make a fearsome noise.
Old Mar 18, 2014 | 04:27 AM
newguy's Avatar
Maybe flex plate?
Old Mar 18, 2014 | 07:09 AM
LannyL81's Avatar
Heffty: if your Blazer is a 4wd, it is probably the front differential is slightly engaging. The gear grinding noise you hear is just that.
Is it a 4wd?
Old Mar 18, 2014 | 05:17 PM
Heffty's Avatar
Yes it is a 4x4. I thought that might be the problem too...and it may very well be but I'm not sure. I put it in 4x4 high but the sound didn't go away. Then I put it in 4x4 low and back into 4x4high then to 2x4 to see if I could get whatever is in there moving around a bit. But the problem still exists.
Old Mar 18, 2014 | 05:54 PM
Naydrus's Avatar
Naydrus is on a distinguished road
I had a similar issue....my transfer case turned out to be the culprit. When I was driving it sounded like it was coming from the front diff....but when I got it up in the air, put it in drive and could listen from underneath, it was coming from the transfer case.
Of course being the idiot I am...I left it. Then winter came and i needed 4 wheel drive.
Well the lets jusst say it got real loud and a new transfer case from the wreckers was installed.
Old Mar 18, 2014 | 06:21 PM
Heffty's Avatar
how much is a new transfer case?
Old Mar 18, 2014 | 08:24 PM
julianmunchkin's Avatar
julianmunchkin is on a distinguished road
Check your front differentials gear oil too, mine mad a nice loud whine when it was low
Old Mar 22, 2014 | 09:00 AM
Heffty's Avatar
The problem is the rear differential. There is a leak that is visible and that is where the grinding sound is coming from. I jacked the vehicle up, put it in drive and then with a metal rod I put it on the diff as the wheels spun. Grind Grind Grind in there going on. So now I guess I either have a big job ahead of me or I just lay the Blazer to rest and move on. A mechanic said he'd put a new one in for $1000 including parts/labour. The 1999 blazer has 255,000km on it now, so if I do put money in it, what's going to go next? How much will that cost? Also...the blazer is a pig on gas as we all know and I mostly do city driving. The fiancée figures we should just buy a chev cobalt or something like that. I suppose I could always try to go to the wreckers and find a rear end to replace mine with...but I'm an electrician, not a mechanic so that task seems time consuming and daunting.
Any suggestions?
96jimmyslt4x4
Jul 18, 2011 10:08 PM
davidsv8mustang
Dec 8, 2010 10:23 AM
chellebear187
Oct 15, 2010 06:50 AM
k5009
Jul 19, 2010 12:34 AM
watsonracingteam
Aug 25, 2008 04:03 PM
