Is this GM Fuel Pressure Spec Unachievable?
Is it possible that the injector body is cracked or defective and is allowing high pressure fuel right into the return port?
Do you get any pressure build at all then it leaks down slowly? Or you get zero pressure and it all pours into the return jar? I would think a small leak could be a small crack or leaking O-rings. No pressure at all has to be a large leak that should be obvious.
I do not get any pressure at the Schrader test port whatsoever, not even 1 psi. My pump can generate substantial pressure. And there are no external leaks from the fuel injector body, poppets, fuel pressure regulator or anywhere else. The fuel just goes down the return line into the jar. It does seem a little surprising that it does not leak sitting on my work bench, but when pressure is applied, it cannot hold any at all.
Rugbygod1969
Jun 18, 2009 06:26 PM
2001Blazer4x4
Mar 2, 2005 10:45 PM
