Going through starts
Old Sep 24, 2009 | 01:27 PM
ratpacks2000blazer's Avatar
ratpacks2000blazer is on a distinguished road
Question Going through starts
This is my husbands truck but he's at work so here goes. Its a 2000 blazer 4.3L. The starter has been replaced 3 times in a very short time frame.The flywheel is good.But it keeps making the awful noise when its started. We have tried shims also. Someone has just told us about a starter bracket that could be missing. So my question is does this sound right and can anyone tell me more about it. Thank you for reading my post.
Old Sep 24, 2009 | 01:58 PM
old skool luvr's Avatar
i haven't seen a bracket on any of the ones i've played with. what is happening to the starters that causes you to replace them? can you describe the noise? is it like something is chewing itself up? rubbing/binding?
Old Sep 24, 2009 | 02:12 PM
Its making the sound like I am trying to restart it. I guess sorta like chewing it self up. The last starter actually cracked. After its restarted a few times it wont start anymore until we replace the starter.
Old Sep 24, 2009 | 04:01 PM
like the engine is alreay running, and you've tried to restat it? that's really wierd.
how long have you guys owned the truck, and why did you replace the first starter?
Old Sep 24, 2009 | 04:22 PM
we have only had it about a year but we were told it needed a starter when we purchased it. It sounds like the starter is engaging and disengaging. The fly wheel was marked and turned and looked good. We don't drive it very often because of this, so it sits and we keep trying.
Is it possible that the transmission was changed and the torque converter was not. Could this cause a problem with the flywheel which in turn is breaking the starter?
Old Sep 24, 2009 | 07:57 PM
midnightmekanik's Avatar
midnightmekanik is on a distinguished road
Sounds like the flexplate (flywheel) might be the problem. I've seen the teeth get chewed up pretty good from bad starters. If the flexplate teeth are worn down, no amount of starter changing will help it. Unfortunately, changing the flexplate requires the transmission to be removed. It's sad that there would need to be sooo much labour to change a $70 part!
Old Sep 24, 2009 | 08:16 PM
thanks everyone
Old Sep 24, 2009 | 09:20 PM
she said,
[quote=ratpacks2000blazer;248345]The flywheel is good..........quote]
and you said,
Originally Posted by midnightmekanik
Sounds like the flexplate (flywheel) might be the problem............
we need to clarify what is in your truck ratpack, is it stick (flywheel) or auto (flexplate)? it does make a difference, and helps us, help you, with your problem.
Rusty Nuts
Mar 13, 2015 12:58 AM
BlackBeauty43
Nov 20, 2013 07:57 PM
89Recon
Dec 23, 2011 07:46 PM
PaulO2288
May 22, 2011 03:23 PM
strongboy2005
Feb 13, 2006 04:38 PM
