Grease points?
Old Jun 21, 2008 | 02:30 PM
Mickeymouse's Avatar
Mickeymouse is an unknown quantity at this point
Default Grease points?
Hi again....
Does anyone have maintence schedule for the grease points? Where and what you should grease up?
I'm not sure that "grease point" is the right name for it? But I'll hope you understand what I mean?
/Michael
Old Jun 21, 2008 | 04:29 PM
timo's Avatar
timo is an unknown quantity at this point
Default RE: Grease points?
uppper and lower ball joints, located right inside each front wheel, it's what they pivot on. VERY IMPORTANT! Pitman arm and tie rod ends. 7 points total on the front end. You may have to feel around and find the grease points. Any place where there is a pivot point you should be able to grease it. If you find a point that does not take grease change the zirk (the thing that a grease gun fitting fits over). Also check U joints.
Old Jun 21, 2008 | 04:30 PM
timo's Avatar
Schedule, when you change the oil. 3000 miles
Old Jun 22, 2008 | 10:34 AM
Ok thanks alot, now I know I didn't miss any of them.... There are no grease ponits in the back?
Thanks again
//Michael
Old Jun 22, 2008 | 01:06 PM
rriddle3's Avatar
Hopefully, the Forum posting feature will work for these diagrams of the lube points.
[IMG]local://upfiles/4800/90ADB6906DA44D2980C48D8FE18862B3.gif[/IMG]
(1)
Transmission
(2)
Rear Axle Differential
(3)
Transfer Case
(4)
Clutch Actuator
(5)
Brake Master Cylinder
(6)
Engine
(7)
Front Wheel Bearings
(8)
Front Axle Differential
(9)
Oil Filter
(10)
Front Propeller Shaft
(11)
Steering Linkage
(12)
Ball Joints
FIGURE Lubrication Fittings (Driver Side)(c)
[IMG]local://upfiles/4800/F5BCCBDDA0AD4B44A4E2CF65E412FD69.gif[/IMG]
FIGURE Lubrication Fittings (Passenger Side)(c)[IMG]local://upfiles/4800/95DE1824323D47B3BC540D38B0A1D689.gif[/IMG]
[IMG]local://upfiles/4800/21E2F5FFE6E245C9BB2E3A9BD9022B9F.gif[/IMG]
(1)
Ball Joint Lubrication Fittings
Old Jun 22, 2008 | 03:05 PM
Thanks excellent. Is there anything else you should consider doing wile you are serviceing you veichle.......
Thanks guys....!!
//Michael
frisco204
May 12, 2014 03:15 PM
musclecar70sfan
20
Jan 5, 2010 07:42 PM
dirtbagger
Feb 27, 2009 09:28 AM
stevelknievel
Feb 29, 2008 10:39 AM
ZR2003
Oct 15, 2007 07:38 AM
