safe jacking/jackstand points?
Old Dec 30, 2009 | 12:17 PM
musclecar70sfan's Avatar
musclecar70sfan is on a distinguished road
Default safe jacking/jackstand points?
hey guys, I was wondering what are the jacking/jack stand points on my 94 S15 Jimmy. The only parts that I'm confident to use right now are the spare tire jack points. Thanks!
Old Dec 30, 2009 | 01:08 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
the entire frame works good
Old Dec 30, 2009 | 01:10 PM
abig84's Avatar
S10s have lots. Anywhere on the frame is fine. There should be a front crossmember under the engine that will work. Just dont use the radiator support. Rear axle works fine too
Old Dec 30, 2009 | 02:40 PM
WolfPack's Avatar
Originally Posted by abig84
{snip} Rear axle works fine too
As long as you have a jack that is safe to cradle the tube...otherwise...slippage is possible.
Ive also heard never jack on the differential housing, stick to the tubes.
Old Dec 30, 2009 | 02:57 PM
Blazin_Jason's Avatar
Eff that, I always jack up the pumpkin.
Old Dec 30, 2009 | 04:32 PM
I have always jacked on the pumpkin as well. Never had an issue.
Old Dec 30, 2009 | 04:56 PM
WolfPack's Avatar
Weird. Wonder why the people who've told me that did..
Old Dec 30, 2009 | 05:59 PM
Sisk's Avatar
yeah i always use the pumpkin too. you have an entire frame to jack wit too dont forget. the frame is normaly pretty solid
Old Dec 30, 2009 | 06:17 PM
old skool luvr's Avatar
i've never heard of that one either WolfPack.
besides the frame & diff, i've lifted off the LCA too. never had any issues-or slips.
it all comes down to how good of a jack you have. don't be trying to lift your truck with one of those 2 ton, 24" long jacks, they're just not stable. have a nice size 3 ton floor jack (or a sturdy set of ramps) for stability. even though your truck isn't low like qtips there, they make some nice low profile ones too.
Old Dec 30, 2009 | 07:17 PM
NC93BLAZERLT's Avatar
NC93BLAZERLT is an unknown quantity at this point
This works in a pinch!!! LMAO! Yes, I actually left it like this while I changed rear ends in NC!
Attached Thumbnails safe jacking/jackstand points?-100_6902.jpg
