hard to start
Old Mar 22, 2011 | 04:04 PM
onder's Avatar
onder is on a distinguished road
Unhappy hard to start
starting my 2000 blazer was hard. it was cranking and no start but second try it will start right away. so i thought maybe its time for a tune up so i changed my air filter, my cap and rotor also the spark plugs and wiring. i cleaned my maf sensor and my egr valve. but it didnt change on starting. my next thing will be changing my battery cables bc when i took my car to the firestone they told me i need to replace them. i dont know how to do it and any other suggestion what could it be a problem. i do have a sound system in my car but my lights dont dim or flicker. but when i accelerate if i pass 3000rpm my lights will dim i noticed that.
Old Mar 22, 2011 | 06:10 PM
Have you checked fuel pressure and leakdown?
https://blazerforum.com/forum/2nd-ge...agnosis-45941/
Old Mar 23, 2011 | 05:47 PM
onder's Avatar
ok i will do that over the weekend. so the pressure suppose to be stably at 60 psi when i turn the key on?
Old Mar 23, 2011 | 06:08 PM
When the pump is running, engine off, pressure must be 60psi to 66psi.
When the pump shuts off, pressure will drop slightly but it must remain above 55psi for at least 10 minutes.
Old Mar 23, 2011 | 06:58 PM
onder's Avatar
thank you i will do that maybe tomorrow.
Old Mar 24, 2011 | 06:58 PM
onder's Avatar
I did the test and there was enough pressure in the system
Old Mar 26, 2011 | 05:05 PM
onder's Avatar
could it be my starter??
Old Mar 26, 2011 | 05:28 PM
In your first post you said the starter was cranking, doubtful that's the problem. What were your pressure readings for fuel pressure? How long did it remain above 55psi?
Old Mar 26, 2011 | 05:56 PM
jdub9000's Avatar
jdub9000 is on a distinguished road
like captainhook said the psi must be at 60psi when you start... the central port injection is a weird and bad idea in my book and WILL NOT open the injectors on start up unless there is 60psi at the unit... 59.5psi wont open the injectors even... when you crank for about 3-4 seconds the vaccumm fuel pressure regulator kicks in and will drop the psi to around 43psi... a few other things to think about--- distributor shaft is carbon fiber and is known to twist and throw off cam position sensor, the cam position sensor itself could be bad, crank sensor could be bad but those should throw a code---- does your tach move when you crank?
Old Mar 27, 2011 | 06:12 PM
onder's Avatar
ok i did the test again. the pressure when i turn the ignition on (engine is not running) is between 57 and 58 and it goes down to zero in 10 seconds so what should i do next i was reading the thread that captain hook posted but i didnt understand it. thank you guys for your helps
