hard to start
Old Nov 29, 2012 | 12:41 AM
  #21
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Just dont ever pull the lines out of their holes. Chances are very good that you will damage them, my neighbor and i just simply pulled one out and put it back in with no force and damaged it.
Also if by some unlucky chance you do need to replace the entire assembly, the new retainer bracket is included with the Delphi spider on rockauto
Old Nov 29, 2012 | 02:33 PM
  #22
colesdaddy02's Avatar
colesdaddy02 is on a distinguished road
97cherryblazer,are you talking about the fuel lines or the poppet nozzle lines.On the fuel lines that go into the top of the spider, I disconected behind the distributor first then up on the intake and lifted them straight up.I sure wish I had a stubby 16mm for behind the distributor.Thanks
Old Nov 29, 2012 | 03:01 PM
  #23
50lb_cat's Avatar
Definetly the poppet lines, don't remove them unless you plan on replacing them lol. Sorry to but in lol.
Old Nov 29, 2012 | 04:30 PM
  #24
Yeah the poppet lines, For those fuel lines behind the distributor i found that a small crescent wrench worked wonders lol
Old Nov 29, 2012 | 05:48 PM
  #25
Oh yeah,I pulled a couple of the nozzles out to check the ends that go into the lower manifold.Good idea on the small crescent wrench.Going to order the parts tonight.
Old Dec 6, 2012 | 04:49 PM
  #26
Alright,got problems now.I replaced the pressure regulator and it is not leaking fuel from the back of it anymore.I checked the poppet nozzles for leaks and no leaks there.Put the plenum back on and put everything back together.Started the truck and now has a terrible miss.I had to disconnect the three plug wires on the right side of the distributor to get easier access to the fuel line connections so I thought that might have something to do with the miss.So I rechecked and made sure they were all put back correctly.Its showing a p0300 and a p0122.Any advice on were I should go from here?Thanks.
Old Dec 7, 2012 | 12:25 AM
  #27
50lb_cat's Avatar
Are you sure you got the spark plug wires and the throttle position sensor hooked up correctky?
Old Dec 7, 2012 | 04:50 AM
  #28
yea,I checked and rechecked the plug wires and the TPS seems to be pluged in correctly.I even pulled one plug wire off at a time to see if there was any change to isolate what wire was bad but it didnt seem to make a difference.Also, it seemed like the truck took a long time to shift into second gear when I took it for a test drive.Do you think the missfire could be fuel pressure related.Thanks
Old Dec 7, 2012 | 08:23 PM
  #29
anybody got any ideas?
Old Dec 8, 2012 | 01:26 AM
  #30
50lb_cat's Avatar
do you have access to a scan tool that you can check the cam shaft retard? It should be 0 degrees plus or minus 2 degrees. But that doesn't explain the tps low voltage.
