Hard Start After Engine is warm
Old Dec 3, 2012 | 12:24 PM
freeman43's Avatar
freeman43 is on a distinguished road
Default Hard Start After Engine is warm
I've checked some other threads and while similar, most are for a different year. So maybe your guys can point me in the right direction.
Main Problem - 2001 Chevy Blazer 4DR - 4WD - Blazer starts perfectly after sitting over night or after an 8 hour or more period. Very hard start when engine is warm, usually will take 3 to 4 tries before finally turning over.
Yesterday I had an issue where the engine would not even crank, and I could here the thud of the starter solenoid, eventually after several attempts I got it started again. So I thought starter is going, so I replaced it, but engine still takes 3 to 4 tries to start when warm.
Things done within the last year:
1. Replaced Starter
2. Replaced Fuel Pump
3. Replaced Fuel Filter
4. Replaced Fuel Relay
5. Replaced Spark Plugs
6. Replaced Cap, Rotor and Wires
Where else should I look?
Thanks is advance
Peter
Old Dec 3, 2012 | 12:28 PM
50lb_cat's Avatar
What brand did you use for the tune up and fuel pump? On those items its very important to use delco or delphi. I would start with a fuel pressure and leakdown test to determine if the problem is in the fuel system.
Old Dec 3, 2012 | 12:45 PM
aa21830's Avatar
aa21830 is on a distinguished road
I had this problem with my '96 Sonoma. Always took 3 tries to start when warm. Problem seemed to go away when I replaced the lower intake manifold gaskets.
Old Dec 3, 2012 | 12:52 PM
freeman43's Avatar
Thanks Gents.
The fuel pump was replaced by a shop, so I'm not entirely sure what brand.
I have a fuel pressure gauge, so I'll give that a go.
Other then the Fuel Pump, Filter or relay, what else fuel related could cause this?
Thanks
Peter
Old Dec 3, 2012 | 02:52 PM
50lb_cat's Avatar
It could be a leaking fuel injector or pressure regulator. Was it doing this before the pump was replaced? You can also look down the throttle body with a flashlight and a dental mirror if you have one. If you see gold spots or it looks really clean, you know you have a leak in the plenum (either the injectors or fuel pressure regulator). Hopefully the shop didn't put an airtex pump in, they are junk and fail way too often.
syriusly
Feb 23, 2013 07:04 AM
Unlimitedsp
Apr 5, 2010 10:12 AM
midnightmekanik
Sep 26, 2009 01:08 PM
Inferno
Oct 22, 2006 08:56 PM
Not mechanical
Oct 9, 2006 11:23 PM
