Which harmonic balancer should I get?
Old Apr 10, 2012 | 11:29 PM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Which harmonic balancer should I get?
I know that my Harmonic alancer needs to be replaced. I was looking at RockAuto and noticed that there are 3 different kinds made by ACDelco. All of them are at different price ranges. I didn't really see much of a difference between them and didn't know which one I should get. Are there any differences between them aside from the cost?
Old Apr 11, 2012 | 07:24 PM
LRV31's Avatar
LRV31 is on a distinguished road
The harmonic balancer you want is the AC Delco #10224885 / $69.79.
The cheapest part listed there is the Crank Pulley that bolts to the balancer and the most expensive one is the Balancer Shaft that is inside the motor.
Old Apr 11, 2012 | 08:26 PM
Klturi421's Avatar
Ohhhhhh...I see it now. From the pictures I was confused.
Any idea what size socket the crankshaft bolt is? Im going to try and borrow as many tools as possible without purchasing and when I pick up the breaker bar and socket, I want to make sure I got the right one. I have been scouring google and this forum but have not come across the answer yet. Still searching.
Old Apr 11, 2012 | 10:43 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Crank bolt is 5/8" or 16mm, also will need a 14 or 15mm to get the crank pulley off the balancer. The balancer also needs to be pulled off with a puller.
Old Apr 20, 2012 | 09:50 AM
Klturi421's Avatar
Alright so I got the balancer and tools for removal and installation. Now how do I prevent the crank shaft from turning? I have seen something about using a screw driver and wedging in the flexplate teeth. I havent found much further info on the removal process.
Is there an 'easy' way to keep it from spinning?
Old Apr 20, 2012 | 11:03 PM
joshua_mullins's Avatar
joshua_mullins is on a distinguished road
Default shadetree mechanic
Best way would be impact wrench. If that's not possible you may have to use something to hold it but be carefull not to bust anything causing more problems! Also probably gonna need a puller to get it off when the bolt is off. Sometimes this can be easy sometimes can be almost impossible without impact wrench and puller.
Old Apr 21, 2012 | 08:27 PM
Jase1979's Avatar
Look at where the oil pan meets the trans. there should be 2 rubber plugs sticking out, if you pull one out you can get a helper to hold a screwdriver in the hole against the flywheel while you loosen the bolt
mech cb
Mar 28, 2010 12:31 AM
wilds_dog
Feb 16, 2010 09:16 PM
Katmandu
Aug 22, 2009 10:50 PM
1blkblazer422
Jun 22, 2009 03:04 PM
thehustler211
Apr 14, 2009 06:06 PM
