Has anyone bought a remanufactured Spider injector assembly from rockauto before?
Old Sep 14, 2009 | 07:05 AM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
I know the aftermarket has them new. But they aren't cheap.
Old Sep 15, 2009 | 12:45 PM
blzR's Avatar
blzR is an unknown quantity at this point
IF you have a 1995 balzer OP,the part number you need is:
17113673.Mine was $759.59.
Old Sep 23, 2009 | 08:10 PM
19blazer95's Avatar
19blazer95 is an unknown quantity at this point
I have purchased from rockauto.com, well known brands and low prices.These days its hard to find parts made in the good old U.S.A. but they are out there. Stay away from imported crap. Example, just rebuilt my entire front end myself and took it to the alignment shop.While there the mechanic said i had a little play in the pass. side hub bearing, i said o.k. ill take it home and come back.Went and purchased a hub bearing and put it in and returned to the shop 3 days later(had to drive it to work ) . The mechanic said the wheel was about to come off and i was better off with the old unit and that was after 240 of commuting. Took that one back and got a timken hub bearing MADE IN USA . no problem since. Had problems with foreign motor mounts(premature failure ,4 months) also.
Old Sep 27, 2009 | 10:04 PM
doc4663's Avatar
doc4663 is on a distinguished road
I installed one in mine but i bought mine from AUS Injection . It is a remane and it works just fine . You can get a new pressure regulator from DORMAN and change that for 40.00 bucks if thats the only thing leaking.
Old Sep 27, 2009 | 11:29 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
hi doc4663,
how much did you pay for your injector when you bought it at AUS Injection? do you have a 1995 truck?
thanks
Old Sep 28, 2009 | 12:01 AM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
i bought mine from advance auto brand new with a 1 year warranty 279 bucks, have no issues..i suggest you buy the fuel return lines also.
Old Sep 28, 2009 | 11:42 PM
doc4663's Avatar
Default cost of aus
I think it cost me about 160.00 dollars.
Old Oct 4, 2009 | 10:29 AM
i want to replace everything in there. the spider and the fuel line nut kit? is that whats its called? is there anything else i can replace in there? the fuel pressure regulator comes with the spider right? are there any o-rings that i should buy to?
Old Oct 4, 2009 | 05:27 PM
reelbroke2's Avatar
the spider assembly comes as a complete unit with new o rings for the fuel return lines, the FPR is also attached to the spider..most parts stores wont know what a nut kit is lol but yes thats what the fuel return lines are called.
Old Oct 4, 2009 | 10:59 PM
there is also a valve on the back of the intake that is used to measure the fuel pressure, is that valve included with the nut kit? my plastic cap is missing and im afriad there maybe dirt in there so i want to replace that too. so does it come with it? or is it sold separatly? and will the little black plastic cap come with it? thanks
