Have two questions about a 1998 blazer lt 4x4
Old Jul 23, 2011 | 04:34 PM
jlg822's Avatar
jlg822 is on a distinguished road
Default Have two questions about a 1998 blazer lt 4x4
I have two questions : 1) I bought a new seat adjuster for my pass. side seat in the front and it wont go on any suggestions?
2) my keyless entry doesn't work really dont know if it does due to the fact that I don't have a keyless entry.
Also Where can I find the spare-tire rim so I can place a spare on it for my truck?
Old Jul 24, 2011 | 06:55 PM
Paul-ish's Avatar
Paul-ish is on a distinguished road
Be more detailed about your seat i dont get that question...
Keyless enrty might just need a battery in the remote...could be wiring...you dont know for sure if you have it anyway?
Look at scrap yards and used adds for a spare.
Old Jul 25, 2011 | 12:08 AM
wrenchturner3529's Avatar
wrenchturner3529 is on a distinguished road
seat adjuster: If you are talking about the handle, push in on the seat around where it would mount. I bet you find that the metal splind shaft is broken and that is why it was missing. They usualy break down the middle where the screw mounts the handle. There is little surface area left to try and remount the handle. After trying to drill, re thread, use on over sized screw. I gave up and bought a $.99 set of small vise grips and clamped them on. Does the job.
Old Jul 26, 2011 | 08:50 AM
lfuller11's Avatar
lfuller11 is an unknown quantity at this point
check for RPO code AU0. for the keyless entry. if you do then check the battery in the remote. You may have to re-program it. Explain more on the spare tire issue.
Old Aug 13, 2011 | 08:48 AM
jlg822's Avatar
Thanks the spare tire under the truck, i need the rim so i can put a tire on it. I went to the junk yard but it the rims that actually go on the truck.... so what do i do?
Old Aug 13, 2011 | 02:21 PM
darknight's Avatar
darknight is on a distinguished road
U can use dat as well for a spear tire.... I would get it.... Matches da rest of ur Rims witch is nice.....
dbleobarbie
Oct 24, 2013 10:08 PM
The_Beast
Mar 27, 2010 06:32 PM
moldeck
Nov 23, 2009 05:57 PM
bezerker
Nov 9, 2009 04:00 PM
