Head bolt broke off when installing the head
Old Aug 25, 2012 | 03:32 PM
viper1ex19's Avatar
viper1ex19 is on a distinguished road
Double Check the length of those bolts and compare to specs.
Even though they're new, it doesn't mean they are right.
Double Check to make sure nothing fell into the bolt holes.
(like pieces of old gasket scrapings or even water won't let the bolt go all the way in)
I have never had a single problem with any Fel-Pro Products.
How sure are you about your Torque Wrench being Calibrated right?
Those bolts shouldn't break off that easy unless they are bottoming out/too long or cross threaded.
I’ve used a Reverse Drill Bit to get them out before, they work great as long as it’s not cross threaded.
Good Luck
Old Aug 25, 2012 | 03:41 PM
echo1's Avatar
echo1 is on a distinguished road
I am using a Sears beam type torque wrench. I will check the bolts. Thx for the help.
Old Aug 27, 2012 | 06:20 PM
echo1's Avatar
I spoke with the machine shop where I had the heads resurfaced. He instructed me to use a 1/8" bit and drill a hole...then insert a 1/8" allen key. I cut off the "L" portion and used a hammer to drive it in the hole and I was able to back out the broken part without removing the head.
New bolts are in and torque down.
Old Aug 27, 2012 | 06:29 PM
burned's Avatar
burned is on a distinguished road
Originally Posted by echo1
I was following the torque settings from this thread:
https://blazerforum.com/forum/2nd-ge...equence-40812/
First Pass In Sequence - 26 ft-lbs
Second Pass In Sequence - 44 ft-lbs
Final Pass In Sequence - 66 ft-lbs or 89.483984587 nm
That's not right.
Follow this guide:
Install Cylinder Heads - Part 9: Rebuilding An Engine To Fix A Rod Knock - GMC or Chevy 4.3 V6
Old Aug 27, 2012 | 07:48 PM
Originally Posted by burned
I agree, those specs are incorrect.
Torque procedure in the link that burned posted is absolutely correct, including the final pass degrees. It is the preferred method straight out of the GM shop manual.
The OP reported in Nm, which is why I responed in Nm, figured he is in Canada. 22 foot pounds and 80 Nm are the same.... guess I should have posted both
Old Aug 28, 2012 | 07:56 PM
dcrews's Avatar
dcrews is on a distinguished road
Make sure you clean out the bolt holes.. Clean out all the old oil you can see, spray it down real well with brake clean, and blow each hole out with compressed air..
If you don't do this, it can cause the same problem, and worse yet, incorrect torque yields. This can cause you to have to do the job over again, in a quick manor....
jbordi
Mar 25, 2011 06:20 AM
kevin turner
14
Feb 9, 2010 06:29 PM
Love to be Blazin85
Sep 7, 2008 01:44 AM
blazer4x4
Sep 12, 2007 11:59 AM
Jorgen
Jul 3, 2007 12:38 PM
