My Fan broke off the water pump and massacred my rad !!!
Old Sep 3, 2008 | 07:52 PM
Love to be Blazin85's Avatar
Love to be Blazin85 is an unknown quantity at this point
Default My Fan broke off the water pump and massacred my rad !!!
I drive a 1995 chevrolet blazer and last week my fan broke off. I could hear a grinding sound coming from my engine, so i pulled over. I had a buddy listen to the engine as i gave it gas. When I putthe peddle down hard the fan broke off at the water pump, the rod snapped. The fan took out the rad like a have never seen before, it was massacred! also many hoses and wires were sheared. Blew my mind.......anybody seen this before????
My friend lived.....ahahaha but he was traumatized for the day
Old Sep 3, 2008 | 08:35 PM
Default RE: My Fan broke off the water pump and massacred my rad !!!
Never before have I seen a stock fan come loose. Did it break the snout off of the water pump or did the water pump fail?
Old Sep 3, 2008 | 09:02 PM
The snout that connects the fan to the water pump broke just inside the pump.......I dont think it failed.......there wasnt any water, but Im not sure. Just before this happened I put the pedal to the floor and nothing was happening, but the engine was still running
Old Sep 3, 2008 | 09:04 PM
can you believe a new rad is 270?? hope I can find one at a wreckers, what do you think??
Old Sep 3, 2008 | 09:10 PM
Its a crap shoot with junkyard radiators. Shop around, you should be able to find it cheaper. RockAuto.com has one for as low as $133 depending on what you need.
Old Sep 3, 2008 | 09:14 PM
Right on.....at least a new water pump is only 60 bucks!
Old Sep 3, 2008 | 09:18 PM
OOPS242's Avatar
OOPS242 is an unknown quantity at this point
Sorry to hear, but was quite funny how you explained it[sm=grinangel.gif] I got a used rad at pull a part cheap, and had it flushed be for putting it in. You type "pull a part" in search, and see if ones near you.
Old Sep 4, 2008 | 06:02 PM
thanks alot.....will have to check that out too!
Old Sep 7, 2008 | 01:44 AM
josh05's Avatar
josh05 is an unknown quantity at this point
had the same problem last week w my 01 the bearings in the fan clutch went out and it dropped the fan into the radiater the part that screws on was still on the water pump new radiater ran me 86 bucks and the clutch was 45 bucks all new bought a used fan at pik a part for 10buks
gitch93
Jul 23, 2013 08:06 AM
Klturi421
Apr 21, 2012 06:56 AM
Fusefinder
Jun 29, 2010 09:20 PM
c4gibson
Jun 6, 2006 02:11 AM
2klt
Apr 2, 2006 11:37 PM
