Head gasket? Blazer '95
Old May 20, 2011 | 08:32 PM
Drkaleb's Avatar
Drkaleb is on a distinguished road
Default Head gasket? Blazer '95
I have a 1995 Blazer with the 4.3 with 210,000 miles. I had a new intake gasket put on a few months ago. It ran fine for a month.
Now I have oil leaking into the Anti freeze but the reverse doesnt seem to be happening. There is also power loss. There is no white smoke coming from the exhaust. The oil doesnt seem milky & the level hasnt gone up.
Is this a head gasket problem? Thanks, drkaleb
Old May 21, 2011 | 07:28 PM
ryansim2025's Avatar
ryansim2025 is on a distinguished road
I'm dealing with this on my 1997 with 150K. I am debating if I need a new head gasket because I'm loosing antifreeze, but my dipstick looks fine. I've lost no power, but don't want to drive the think into the ground through ignorance, nor do i want to put lots of money into an engine that might die soon.
Old May 21, 2011 | 08:22 PM
pheaton's Avatar
pheaton is on a distinguished road
Check the intake manifold gasket.
You may have a bad radiator. This could also be a bad oil cooler if your model has one.
Worst case, you have a cracked head or block. But as always start with the easier stuff first.
Old Jun 6, 2011 | 07:05 PM
Just a follow up, but pheaton called it, it was a cracked radiator. Much better than a cracked head/block. Thanks for bringing it up to my attention!
Old Jun 8, 2011 | 11:42 PM
Drkaleb's Avatar
Ok I will check the manifold gasket but can that cause power loss just like the head gasket?
limited edition 1
Jan 27, 2023 11:07 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
