Headlight flashing between being "on" and "off" after a while
RE: Headlight flashing between being "on" and "off" after a while
ORIGINAL: rewj
Thanks for the response, it is a 1996 Blazer. The buzz comes from the glovebox relay bay, there is one under the dash that I can check?
My truck is also a '96, and the clicking noise is coming from the same place, under the glove box. I have discovered that there are quite a few differences between the '94-97 trucks and the '98-04s, so this may be another one. Bear in mind that a lot of 98+ owners may give you advice based on their trucks that won't apply to yours, even though their intentions are in the right place.
I'm not sure I'd buy the answer from the dealer that it's the PCM (I think that's what you meant), seeing as the high cost of replacing it could be their motivation for telling you that. I'd definitely get a second opinion before replacing it. Good luck!
The headlight relay could be under the dash, yeah...
Psychro, why did you splice in another wire with your H4 conversion? It should've plugged right in...
ORIGINAL: drperry
Click here for more details.
JustaGT
02-19-2013 01:55 PM
fireman846
01-14-2011 09:31 AM
BradensCreed
08-25-2007 03:22 PM
