Headlight replacement question...
Old Sep 6, 2009 | 02:45 PM
MachNU's Avatar
MachNU is on a distinguished road
Default Headlight replacement question...
My pass. front headlight lens is badly cracked, and needs replacing. My brother funs a Advance and I was looking through the system for a replacement lens, and he tells me theres two types. Composite, and I forget the 2nd one. Need to know if the lens is cracked do I have to replace the whole assembly or just the lens?
Old Sep 6, 2009 | 08:31 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Ive never seen a replacement lens alone for sale,im not sure how you would seal it to the headlight assembly. The two headlight types are composite and sealed beam, if have the small bulbs that go into the the back of the headlight assembly its composite, otherwise the bulb is the whole unit.
Old Sep 6, 2009 | 10:02 PM
MachNU's Avatar
Dam thats what I was afraid of. Luckly though, I tested to see if it had a stand alone bulb, without pulling the grill. Low beam is out, but high beam is still there, so pretty sure that its a composite headlight!
Old Sep 6, 2009 | 11:07 PM
portcqb's Avatar
if its composite you have the low in one part of the lens the outside ones on mine, and the high in the second lens near the middle. Also the lens should be plastic, if its a square glass lens then its sealed
Old Sep 7, 2009 | 08:37 AM
MachNU's Avatar
Yeah its on the 95, So i guess its one whole sealed beam!
Old Sep 7, 2009 | 10:05 AM
portcqb's Avatar
Yah if its the glass bulb your actually way better off,its cheaper than both headlight bulbs would be and lens arent cheap new
Old Sep 7, 2009 | 10:21 AM
MachNU's Avatar
just went out and checked it, its actually the plastic, with a dettachable bulb. so i already found the headlight I need!
http://cgi.ebay.com/ebaymotors/HEADL...Q5fAccessories
evfeez25
Jul 12, 2018 01:45 AM
xfact0r3
May 16, 2013 03:30 AM
toms2000blazer
May 12, 2013 02:04 PM
Maxboost25psi
Mar 13, 2013 03:54 PM
tiw1990
Jan 13, 2012 12:05 AM
