Headlight troubles???????????????
Old May 13, 2010 | 11:47 PM
sticky23's Avatar
sticky23 is on a distinguished road
Default Headlight troubles???????????????
Hi guy's.I have a 2000 Chevy Blazer.My DRL lights work fine,but at night my lowbeams will not work.I have slammed the hood and they have came on before or I have opened my driver door and they have came on.Ive tried turning the headlight switch on manually still nothing.When I bought the truck they worked.Then one night when driving home they went off and then came back on and went off again.I have changed the relay the on/off switch and checked the fuses.They are all fine.My running lights work but my headlights wont come on.Please help????????????????????
Old May 14, 2010 | 01:56 PM
shligger's Avatar
shligger is on a distinguished road
It sounds like you have a loose wire. Trace the wires from the head lights and see if you can find any frayed wires, loose connections or damaged wire.
Old May 14, 2010 | 05:25 PM
84BlazerS10's Avatar
Yeah, definitely check your wiring.
Old May 14, 2010 | 06:55 PM
Benedict1337's Avatar
DRLs are your high beams. check if your high beams work. if they do it sounds like a wire went loose somewhere on your low beams
Kellogg
Jan 31, 2010 04:28 PM
jaybird33081
Jan 4, 2010 11:19 PM
baja457
Oct 28, 2007 08:21 AM
getonerd
Sep 28, 2007 07:20 PM
2blzers
May 13, 2007 09:09 PM
