Headlights
Old Sep 24, 2007 | 06:10 PM
03blazer's Avatar
03blazer is an unknown quantity at this point
Default Headlights
My drivers side headlight burned out so i replaced it and when i went to put it back in there was a big gap between that chrome strip and the headlight. i tried to put it in different ways but couldnt get rid of that gap. anything i can do to fix this? thanks for your help.
Old Sep 24, 2007 | 06:24 PM
rriddle3's Avatar
Default RE: Headlights
Maybe this will help.
Old Sep 24, 2007 | 07:02 PM
03blazer's Avatar
hey thanks but it looks like i am going to need to remove my grill. how do i go about doing that?
Old Sep 24, 2007 | 08:49 PM
blazin97's Avatar
blazin97 is on a distinguished road
just pull its only held on by 6 or so clips
Old Sep 24, 2007 | 08:54 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
You shouldnt have to remove your grille to do this. It just takes a little finesse to get those suckers back in. Just try and try again. I find if you can get the bottoms in, then pull up just slightly you can get the tops in and then push downwards. Then attach the tab holders and then your done. Hope this sort of helped. It took me quite some time to figure out how to make them go in right, but once you figure it out it should go smoother.
Old Sep 25, 2007 | 05:31 PM
03blazer's Avatar
Thanx for all the help guys! after i removed the grill it took 5 seconds to put the headlight in correctly! =)
hollywoodgrad
Jan 25, 2012 01:58 PM
AzBlazer
Jul 3, 2005 04:17 PM
FatRyan
Mar 8, 2005 03:27 AM
BlazerSquad93
Feb 17, 2005 11:52 PM
jaleg
Nov 17, 2004 02:53 PM
