Headlights with electric up and down movement 2000 Blazer LS 2 door
The screws for adjusting the headlights up, down, left and right are broken on my 2000 Blazer LS
I have tried to google the adjuster screws and new headlights but have not found any are the same type as on my car because the plate that fastens the headlights using 2 clips have an electric motor used to adjust the headlights up or down using the wheel mounted on the headlight switch
Any know where i can find new adjuster screws or the plate that holds the headlight?
The first 2 pictures are of the broken adjsuers and the last picture shows the wheel on the headlight switch that adjust the headlights up and down
Well i guess that explain why i have not been able to find the parts on US web sites.
It is pretty common here in Europe since you adjust the headlights if you pull or have a lot of weight in the back or pull something heavy using a trailer so the car sits low at the back for example
Having said that Mercedes is the only car that have had this as a standard for several years
half_full
03-29-2014 03:17 PM
punx.inc
12-25-2007 12:07 AM
