Headlights flicker while braking
Old Apr 3, 2010 | 06:02 AM
kgpace's Avatar
kgpace is on a distinguished road
Default Headlights flicker while braking
Hello Forum. I have recently noticed that there is a slight flicker of the lights when tapping the brakes on a 1997 Blazer. One time it actually shut off at idle when engaging the light switch. Could this be a ground issue? I have been told that there are combined or stacked grounds on the frame that are a common problem. Switch possibly? Any help is very much appreciated.
I observed the lights early this morning and it seems to be more prevalent, sitting at idle tapping the brakes.
Old Apr 3, 2010 | 03:52 PM
4pt9fiero's Avatar
4pt9fiero is on a distinguished road
I would start by cleaning up the grounds, cheapest fix you will find. At 13 years old, I wouldn't be surprised if you had some corrosion.
Old Apr 3, 2010 | 06:34 PM
kgpace's Avatar
Thanks for the reply. Where would the major grounds be located?
Old Dec 29, 2010 | 10:33 PM
street101's Avatar
street101 is on a distinguished road
Exclamation Omg
mine too starter went out and i replaced it , then it started back up this dimming of lights has me puzzled i put new power and grounds and i have HID's they shouldn't flicker at all, did you come up with an answer? i even had the alt tested and they said it was good to go???????????????????????????????????????????????? ????????????????????????
Old Dec 29, 2010 | 11:13 PM
hillwilliam2's Avatar
hillwilliam2 is on a distinguished road
I had this as well for several months. It was time for a new battery this past fall, and when I put it in, I noticed that I did not have the flickering when braking anymore. Maybe check the age/wear on your battery.
Old Dec 30, 2010 | 07:17 PM
kgpace's Avatar
Default Fixed problem
Yep, after months I actually found the problem that was causing so many maladies including anti lock coming on and low charge rate. On my 97 there is a small black junction box drivers side, on fender near anti lock system. I removed the plastic cover and there are 4 heavy hot wires that feed several items in the vehicle. One of those was melted and heavily corroded. The other three were getting corroded too. I repaired the two wires and cleaned the others and reinstalled it. No more problems and the alternator and fuel gauge actually read correct now. I believe that a diagram shows that as an under hood connection or junction. Hope it works for you.
Old Dec 31, 2010 | 02:30 AM
KHS1907's Avatar
KHS1907 is on a distinguished road
AHHHH this sounds like it could be my problem too! Ive been having circut open and erratic signal codes from my abs system with the abs coming on in the last phase of braking (<15mph) and now that its been mentioned my headlights flicker too under braking. Thabks will look for that box!
Old Jan 2, 2011 | 03:42 PM
street101's Avatar
Exclamation
Yeah its crazy wires and the " JACK WAGON " that had my truck before me had it slammed and took the inner fenders out i checked my wires on the drivers and the heavy hot red wire with a 30A fuse is bad from water, I had ADDHD and i found this out before I came back here, I cut all the plastic off the wires ran them down and the two wires that run from the ALT. go there should have known that dealing with my older chevy C10's well i'll do you guys one better I'm leaving right know I'm going to get a BAT. and REPLACE the 30A fuse and REDO the wires and that junction box on the drivers fender, WE WILL GET TO THE BOTTOM OF THIS
I have changed the starter, alt, and bat. but the bat. was from the junk yard but dated 5/10 i'm still going to get a new one.
poertsch
Mar 4, 2014 08:06 PM
mrkevinmjr
May 14, 2011 05:14 PM
Nizm0
Apr 30, 2010 09:32 PM
marine
Jan 28, 2010 07:05 PM
recruiter
Jan 5, 2007 02:58 PM
