Heat barely blowing..
Old Oct 16, 2009 | 05:04 AM
one.shot.one.kill.'s Avatar
one.shot.one.kill. is an unknown quantity at this point
Default Heat barely blowing..
So I notice todat that my vents hardly blow any air at all. The little that comes out is warm but it just doesn't come out as well as it should.
Any suggestions on what to look at 1st would be great.
It's a 2000 Blazer by the way...
Old Oct 16, 2009 | 11:01 AM
m5james's Avatar
m5james is an unknown quantity at this point
The blower motor is super easy to replace. Remove it and run it in your hand to make sure the motor isn't dead.
Old Oct 16, 2009 | 11:56 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Does the fan sound the same at all speed settings?
Old Oct 16, 2009 | 01:16 PM
No it does not.
Old Oct 16, 2009 | 02:20 PM
rriddle3's Avatar
If the 2000 is like the 2002 (and I believe it is) I wouldn't consider having the cut out a hole in the cover in front of the firewall to get to it, and then having to seal it back up "super easy", but I'm not very ambitious.
Old Oct 16, 2009 | 02:43 PM
m5james's Avatar
Mine is a 90, so it's super easy to replace.
Old Oct 17, 2009 | 02:08 AM
Well for some strange reason its working perfectly fine now.
Old Oct 17, 2009 | 10:19 AM
portcqb's Avatar
you must have scared it into working with all the cutting involved,lol. If it seems to be stuck in low or something like that then it most likely is the blower. Im pretty sure that when the blower resistor goes bad it the other way around you lose low speeds.
xul
Aug 14, 2011 04:57 PM
couve chevy
Jun 15, 2010 07:51 AM
jdoerrer
Jan 24, 2008 10:44 PM
Alex01tib
Oct 12, 2006 04:47 PM
apekim
Jun 30, 2006 04:50 PM
