heat/ cold air problem after heater core
Old Aug 23, 2008 | 03:05 PM
mudd4's Avatar
mudd4 is an unknown quantity at this point
Default heat/ cold air problem after heater core
My girlfriend has a 98 Bravada, which is pretty much the same vehicle. I replaced the heater core. The problem is now it only blows hot air, no matter what setting it is on. I read plenty of topics on no heat but this is no cold air. Did I mess up something with the door when I put it back together?? Or something else? If it is the door, will I have to pull the whole dash again to fix it. I did this awhile back and forgot how it all went together.
Thanks for your help!!
Ryan
Old Aug 23, 2008 | 08:16 PM
Default RE: heat/ cold air problem after heater core
Does sound like there is a problem with the temperature blend door. I would check to make sure that you connected all of the vacuum and electrical connections first.
Old Aug 23, 2008 | 08:46 PM
mudd4's Avatar
I will check again. If it is the blend door will I have to tear everything out again to get to it. It has a split cover, top and bottom. Just wondering where the linkage bolted up as I can't remember. Also is it even possible to bolt it back up wrong? I figured it would bolt up in the same position I unbolted it.
Thanks
zantam06
Aug 4, 2012 02:00 AM
wetbar
Dec 1, 2011 07:01 AM
PRIVATEPILOT
Nov 3, 2011 09:48 PM
mcatnova
May 17, 2010 06:27 AM
woodsballr
Jan 28, 2007 07:17 PM
