no heat, but heater core is good
Old Nov 30, 2011 | 11:09 AM
wetbar's Avatar
wetbar is on a distinguished road
Default no heat, but heater core is good
Hey I have a 2002 blazer that does not have heat. I checked to core and it is not leaking. I ran a garden hose through it so I know it is not clogged. The truck heard up 180 or so but still no heat.
Old Nov 30, 2011 | 11:52 AM
Tubais's Avatar
Tubais is on a distinguished road
maybe you blend doors aren't working? the other options are blown head gaskets.. are you losing water?
Old Nov 30, 2011 | 11:57 AM
chris015's Avatar
I doubt its a head gasket....COULD be...but not having heat is probably another issue..
Is your blower fan working? Is the air blowing at all?
Old Nov 30, 2011 | 03:14 PM
wetbar's Avatar
I have plenty of water, and the fan is working. when I cut on the heat I get 50 degree air, and when I move the temperature control to cold I get 40 degree air. so I think the temperature control **** is working as well.
How do I check the blend doors?
Last edited by swartlkk; Nov 30, 2011 at 04:41 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 30, 2011 | 07:26 PM
brady628's Avatar
brady628 is on a distinguished road
im having same problem. exact!!!! no head gasket issue, no loss of water,fan blows with no problems. after 15 min or so i start to feel very little heat. heats up to 180-200 range.
is it a thermostat?
mine is also a 2002
Old Nov 30, 2011 | 07:38 PM
Ranic85's Avatar
Ranic85 is on a distinguished road
Might be the switch in the dash is faulty.
Old Nov 30, 2011 | 07:41 PM
xgiovannix12's Avatar
your bend door might be stuck open
and its letting the cold air in
Old Dec 1, 2011 | 07:01 AM
wetbar's Avatar
I would think it is not the blend doors cause when I move the temp **** to cold it does get colder a little. Maybe the doors are moving but not shuting. How do I check the blend doors and what **** moved the blend doors, the temp ****?
how do I make sure if it is the blend door or not? I just checked the water again and it is fine. I have no clue what to do next.
Any clues?
IrishRiley
Mar 6, 2015 02:42 PM
mudd4
Aug 23, 2008 08:46 PM
woodsballr
Jan 28, 2007 07:17 PM
arbowman
Oct 24, 2006 09:15 AM
Blue Vette
Nov 14, 2005 02:31 AM
