Heat doesnt work when stationary
Old Dec 8, 2010 | 09:52 PM
Nemo1991's Avatar
Nemo1991 is on a distinguished road
Default Heat doesnt work when stationary
Well as the title says, the heat only works when imn driving. if i come to a stop, it starts to get colder and colder. once i get moving again i have to turn off the heat for about 60 seconds and turn it back on. if i dont do that it will just continue to blow cold air., any idea how to fix this??
also its a 2003 2wd 2dr
Old Dec 8, 2010 | 10:01 PM
blazerpower's Avatar
blazerpower is on a distinguished road
how many miles are on it? when was the last cooling system flush?
Old Dec 9, 2010 | 12:46 AM
itsmeuherel7's Avatar
itsmeuherel7 is on a distinguished road
my heat doesnt work at all it used to then it would go off. i would hit a bump and it would go back on now i get nothing at all its a '97 4WD 4 DR any hints on what the problem could be??? its 29 degrees out im dyingggg!!!!
Old Dec 9, 2010 | 07:02 AM
Nemo1991, does your engine come up to proper operating temperature? If so, it sounds like your heater core may be partially clogged and the condition may be alleviated through a heater core flush.
itsmeuherel7, please do not double (quadruple in this case) post your questions in a bunch of threads, especially threads where others are trying to solve a problem, however similar it is. This question has been answered in another thread which you have posted in already.
Old Dec 9, 2010 | 08:17 AM
Nemo1991's Avatar
yes it does, right around 200 degrees. thanks you ill try that and see if it helps, its only 15 degrees out right now!
Old Dec 9, 2010 | 08:31 AM
dobyken's Avatar
dobyken is on a distinguished road
The link for the core flush is OK but I would advise putting small hoses and clamps on the core to get the water out of the engine compartment. On some models you can get water all over your cap and wires doing it the way it's shown in the pictures....don't want to cause other problems.
Old Dec 9, 2010 | 03:02 PM
terry s's Avatar
terry s is on a distinguished road
This may be as simple as a low coolant level.
EricR
Oct 1, 2011 09:57 AM
njhc
Jan 26, 2011 08:29 PM
NVANZEE
Jun 27, 2008 11:32 AM
stevenf
May 24, 2008 07:49 PM
idg4ever
Jan 22, 2007 07:41 PM
