Heat Issue
Old May 5, 2011 | 05:07 PM
gary h.'s Avatar
gary h. is an unknown quantity at this point
Default Heat Issue
I have a 98 chevy blazer 4x4. My "Service Engine Soon" light came on and I checked the heat output. It doesn't put out heat below 80 degree ish. The light went out but heat still doesn't work below 80. 80 and above it is pumping good heat. Any ideas? Thank You.
Old May 6, 2011 | 10:28 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Im sorry but I dont totally understand your problem. If you can better describe what is happening (80 degrees outdoor temp? engine temp? Milage. ) it would help. Have you pulled the codes? The 2 problems may be totally unrelated. My first gut reaction would be to check the coolant level in the radiator when the truck is cold. Are you the original owner? If so, these trucks had some unique cooling system problems you may need to address.
Old May 7, 2011 | 03:25 PM
gary h.'s Avatar
Thanks. I now believe they are 2 seperate issues.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
jimhens82
Dec 17, 2009 06:32 AM
mcaanda
Dec 15, 2009 08:31 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
