Heat and radiator troubles
Old 01-31-2010 | 05:03 PM
Kellogg's Avatar
Kellogg is on a distinguished road
Default Heat and radiator troubles
A few months ago my truck was over heating and I ended up having to have the radiator boiled out and cleaned and I haven't had a problem since until today. My gauges were reading hot and my heat would go cold as the gauge would get higher. It would get to the far right then go back down to normal then the heat would get warm again. Then the gauge would start climbng and the heat would go cold again and when I got to work I could smell antifreeze. I don't know what the problem could be since I had the radiator cleaned completely this past fall. Also when my truck sits idle wiu the defrost going; itnever gets warm and keeps blowing cold air. Any help would be appreciated.
02 chevy blazer automatic 120000 miles
Old 01-31-2010 | 05:11 PM
rriddle3's Avatar
Start with flushing the heater core both directions and purging air from the coolant system.
Disconnect both hoses to the heater core on the outside of the firewall. Connect a garden hose to the inlet and run water through until it comes out clear. Repeat the procedure for the outlet to the core.
To purge air raise the front of the vehicle with the passenger side slightly higher remove the radiator cap and run the engine to operating temperature watching for air bubbles at the filler neck. Add coolant as needed let the engine cool and repeat procedure. Possibly a third cycle.
Old 01-31-2010 | 05:28 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
x2 on the flush
look into getting a new thermostat too, if its never had a new one put in
krs12369
05-01-2011 01:52 PM
mrd0t
01-08-2011 12:05 AM
bigdaddykane93
01-04-2010 01:03 PM
mcaanda
12-15-2009 09:31 PM
Stopphn
Headers, Intake, & Exhaust
06-01-2008 08:24 PM
