Heat turns COLD while setting in Park
Old Jan 11, 2011 | 06:12 PM
bama1fan's Avatar
bama1fan is on a distinguished road
Question Heat turns COLD while setting in Park
I have a 2002 Chevy Blazer Xtreme, 4.3L V6. I stop the other day waiting on a train to pass. While I was setting in park I notice my heater started blowing cold air out the vents. When the train passed, and I started driving, the heater started blowing warm then hot air again.
Thanks!
Old Jan 11, 2011 | 07:28 PM
Sounds like your heater core may be partially clogged.
Old Jan 11, 2011 | 08:46 PM
bama1fan's Avatar
Going to tomorrow to get a flush and fill! Thanks!
Old Jan 11, 2011 | 08:49 PM
You can do it yourself --> Heater Core Flush
Also, you can confirm that the core is partially clogged by feeling the temperature of the hoses leading into and out of the core. If things are working properly, they both should be hot (around the same temperature).
Old Jan 11, 2011 | 09:07 PM
bama1fan's Avatar
Yea I notice that earlier when I was doing a search here on the forum. It's too COLD to go outside and do it myself right now, but I might do it later when it warms up. The temp is not getting out of the 30s for the next three days! We just went thou a Snow/ice Strom this past weekend. Still have some snow and ice on the ground!
Old Jan 12, 2011 | 07:30 PM
bama1fan's Avatar
UPDATE: I went today to get my Blazer checkout at the Express Oil Change. Come to find out I have a a leaky water pump. The coolant level was low causing my heater not to work right. Thought at first it was the thermostat, but found out there was a leak coming from the water pump. Getting it fixed tomorrow.
chriscrm
Jan 4, 2013 01:19 PM
jojocarreno
May 27, 2011 12:27 PM
madcowz2020
Jan 29, 2009 07:51 PM
rdhack
Feb 9, 2008 10:32 PM
rooster
Jun 7, 2007 08:40 AM
