Heater blowing out cold air
Old Oct 19, 2012 | 05:23 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Get the engine nice and hot and feel the coolant hoses going into the heater core from the engine bay, if both aren't the same temperature, then your heater core is clogged up, happens to mine at least every year.
Old Oct 20, 2012 | 07:28 AM
QUIC's Avatar
QUIC is on a distinguished road
Did you try replacing the thermostat?
Old Oct 22, 2012 | 01:33 PM
Herc130's Avatar
Herc130 is on a distinguished road
Its been over one year since going back to the old style anti Freeze and system is still functioning good.
Old Oct 23, 2012 | 12:44 PM
taylorkunz's Avatar
taylorkunz is on a distinguished road
I had the same problem a while back, the heater would barely start to barely work after a long drive to work. It ended up being my thermostat was stuck open. Cheap and easy fix too.
Old Oct 24, 2012 | 01:57 PM
redz's Avatar
redz is on a distinguished road
I just fixed this on my truck and now the heat is insane...
The problem was the heater core was plugged up... Flushed out the heater core and all my issues were resolved...
Oh Yeah... Also make sure you have coolant in your truck... :P
ReDz
Old Nov 9, 2012 | 11:49 AM
BlazaGuy95's Avatar
BlazaGuy95 is on a distinguished road
Did the Heater Core Back Flush and Coolant Flush and now the heat is working better then ever. Thanks for all your help everyone!
Old Nov 18, 2012 | 03:36 PM
wheeets's Avatar
wheeets is on a distinguished road
Originally Posted by wheeets
please let us know how it goes. i have a similar issue with my 2001 4WD LS. When I have the heat/cold air on sometimes it kicks on, often times tho no air (or really faint air) comes on. Although cold air seems to kick on more frequently.
Figured out my issue. The "Blower Motor" is worn down. My uncle banged it (not too hard) and it came on. He said I can only bang it "on" for a couple times tho. it needs to be replaced. In the words of Homer Simpson: "Doh!"
Old Nov 19, 2012 | 05:51 AM
mmmrodge's Avatar
mmmrodge is on a distinguished road
check the anti freeze level. mine was low and at idle i wouldnt have heat. was half a gallon low
Old Dec 23, 2013 | 05:15 PM
Ron G's Avatar
Ron G is on a distinguished road
Having the same problem with a 98 blazer ,, I changed thermostat and flushed heater core but still blowing cold air , guess I'll flush whole coolant system and replace it with the green stuff.
Old Dec 30, 2013 | 10:44 PM
chief80's Avatar
chief80 is on a distinguished road
Default Heater Blowing Cold Air
Thanks for all the information. I took the easy way first and followed the lead of checking the hoses leading into the heater core. Low and behold the one was warm and the one closest to the drivers side cold. I removed the hoses and sprayed a garden hose into the heater core flushing it out until clear water ran and to my surprise the heat is flowing again. Now for the gas guage that seems to have an electrical issue and jumps from true reading to empty.
