Two Problems
Old Jan 7, 2009 | 09:21 PM
whitezombie198's Avatar
whitezombie198 is an unknown quantity at this point
Default Two Problems
I own a '95 4 door blazer with the 4.3 engine. The other day i was on the highway and I felt a strange rumbling that felt like I was running on the rumble strip when I wasn't. Then, I was trying to back out of my friends driveway and it seemed like it just didn't want to go. It almost seemed like I was trying to pull something and It just didn't want to go
Old Jan 9, 2009 | 12:50 PM
Funkydrummer57's Avatar
Funkydrummer57 is an unknown quantity at this point
Default RE: Two Problems
Check your sway bar bushings for the rumbling issue
Here is some info on where to find it depending on whether you have a 2wd or 4wd
http://www.autozone.com/shopping/rep...00c152800c012a
May not be the cause cause there are many things on your suspention that could cause the issue.
Also does it seem to happen when you hit bumps and go around turns? or is it constant rumble no matter what speed or road your driving on.
Sway bars bushings / links are worth checking because they are easy to see and a relatively easy/cheaprepair.
Other issues could be anything from shocks to engine mounts could you describe it in more detail?
And does it feel like it has no power in Reverse only or also when you start driving?
Old Jan 9, 2009 | 01:09 PM
rriddle3's Avatar
Have the symptoms shown up other than those two times?
Old Jan 9, 2009 | 02:58 PM
G_78_91_k5blazer's Avatar
G_78_91_k5blazer is an unknown quantity at this point
Check motor mounts and U-joints
Old Jan 12, 2009 | 06:05 AM
The rumbles only did happened that one time and it was just short little rumbles, kind of like a rumble strip. And with the backing up problem, It will feel like a couple of little tugs and then Its a gamble from there. There are times it feels like it doesn't want to move and then it will go just fine.
Old Jan 18, 2009 | 12:58 AM
blzR's Avatar
blzR is an unknown quantity at this point
U-Joint,please inspect!I just about lost my entire driveshaft down the highway,very close call holding it all together.
dman001948
Jun 21, 2011 10:01 AM
The_Beast
Mar 27, 2010 06:32 PM
CNYCountryKidd
Dec 6, 2009 05:00 PM
miller_1787
Feb 19, 2007 04:23 AM
drefda
Dec 14, 2006 01:37 PM
