Heater core removal.....HELP!!!!!
TDANNAR,
Thanks for the good info. My heater core just let go too. My heat quit working last winter, so I flushed the system and it seemed to be ok. It made gurgling noises under the dash from time to time, but I thought I just couldn't get it bled completely. Today, I started smelling antifreeze and the windows fogged up. So, looks like I'll be replacing my heater core too. Problem is, I'm in Italy. I just ordered a new core online, so will have to wait a week or two until it gets here. I have a Haynes manual that describes the dash removal process and the evaporator box removal, but it doesn't list all the bolts you did. Does the dash have any tricky screws or bolts to get to? Did you have to lower your steering wheel? Any other tips or tricks you can pass on? Thanks again for the info.
Verge
Verge
Verge,
Not really a big deal, just time consuming. My experience is on a 98 and I think every thing from 98 on would be the same. If your vehicle is older than 98, could be somewhat different.
The column is lowered, not removed. I removed both front seats and the console to give me more room and that only adds an hour or less to the total. To remove the seats, there is a star head bolt on the inside/rear seat track. No big deal, unless you don't have a star socket. When you have the seats out, who knows how much change you may find on the floor. You might find enough to pay for the core.
No special tools needed other than that. When I removed the dash, I took several bags and put the screws in and marked the bag for the area that the screws came from. Really makes assembly a lot easier, that way you have the correct screw and correct length at each level. The only wires that have to be removed/unplugged is the main harness and passenger side airbag. No speedo cable or anything. When you remove the lower dash panels, there was a courtesy light that I took off and you have to remove the emergency release cable which is simple, just look under the dash where the cable attaches to the release mechanism, hold up on the lever and the cable comes right out. I removed the radio and may not have needed to as I think I could have gotten to the antenna wire when the dash was tilted out. The radio antenna wire has to be slid out of some brackets so it doesn't get hung up when the dash comes out. I removed the glove box and again, don't think that was necessary. You can hold up on the metal spring that stops the glove box when it is open (on the upper left corner of the glove box when it is open) and the glove box will pivot down to give you access to the main wiring harness and the airbag connector. Under each speaker grill is one bolt that has to be removed. The speaker itself does not need to come out, just the bolt toward the front by the windshield. When you pry up the trim panel around the defroster, be careful, mine was already broken, and they are not that sturdy. There were 4-5 bolts under there.
When you remove the right inner fender, there are several bolts around the edge of the fender, a couple above the tire and, I think, three at the very front. My Blazer sits kind of high and I did not need to remove the tire. You will need to also pull the battery and battery tray. Leave the computer and water reservoir on the fender. The inner fender will drop down far enough to get to the nuts that you need to remove on the bottom of the evaporator case. The inside one is somewhat hard to get to, I used a ratchet wrench to get to it. I think they are 10mm.
I have a few detailed photos if you need.
I could use a contact in Italy. I have a Moto Guzzi Lemans and a Lambretta that sometimes give me fits!
tdannar,
I tried to reply the other day, but it wouldn't let me for some reason.
I've got a 2000, so it should be about the same.
Once again, thanks. My Haynes manual said nothing about taking the inner fender off. You saved me alot of time
I know absolutely nothing about motorcycles or scooters, but if you need something for yours let me know. I'll see what I can do.
Thanks again.
Verge
Thanks again.
Verge
So..
My 2000 LS Blazer's heater core has finally let go.
I have removed the dash and the nut near the heater hoses and the screw behind the distributor.
Now, Where exactly do I cut the AC Box to get to the other screw?
AND did someone say there were 2 I needed to get to by removing the inner fender?
(Are these the ones that screw to the "legs" under the glove box? )
Anyone got pics? I'm getting very frustrated.
click my sig and look through my album for some HC pics. Search through my old posts for a wealth of HC replacement info. personally removing the seats and console is a bit much. there are 4 screws ontop and two bolts under the dash. unhook the wires and tilt it forward. for dropping the stearing wheel down i just droped the weel on my seat and let the wheel rest on it. HC is actually a really simple swap out. its just intimidating! hope it helps.
Example:
Example:
sean bamf
28
Jan 9, 2008 07:18 PM
aspenpup
Jul 3, 2005 06:56 AM
