Heater Hose Inlet Fitting
Old Oct 18, 2012 | 07:21 PM
Jesster's Avatar
Jesster is on a distinguished road
Default Heater Hose Inlet Fitting
I had a coolant leak that seemed to be coming from above the oil pan on a 1996 Blazer 4dr 4wd. I have since traced the leak to the threads on the inlet heater hose fitting (see photo) that comes from the top of the intake manifold. I have some thread sealer (see photo) that I believe would be appropriate, but the fitting seems to have something like regular plumbing pipe dope on it. Would my existing thread sealer work here?
The rubber washer that was inside the fitting on the threaded side (see photo); what is this washer for? Do I need it?
The fitting looks fine, but could the fitting have corroded through?
Attached Thumbnails Heater Hose Inlet Fitting-blazer-heater-hose-inlet.jpg   Heater Hose Inlet Fitting-threadsealer.jpg
Old Oct 19, 2012 | 06:44 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
Glad you found the leak. The sealant shown will work fine, just make sure all the threads are clean and dry before assembly. It looks like standard NPT threads on the fitting end so I don't see why a rubber washer was used there. Hope someone else knows.
<3blazer
Headers, Intake, & Exhaust
Jul 13, 2009 11:09 PM
ncmudblazer
Jun 5, 2008 03:50 PM
burak sozer
Jun 4, 2008 02:05 AM
ratwell
Dec 16, 2007 09:50 AM
