heater house question
Old Apr 22, 2008 | 07:42 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default heater house question
Ok im going to do a cooling system flush with that flush kit thing with the T and the spout. The T needs to be connected into the heater core inlet hose. Which hose is this I know its one of the two going into the firewall?
Old Apr 22, 2008 | 08:01 PM
WolfPack's Avatar
Default RE: heater house question
I put mine in on the level part right on top of the engine behind the alt.
Make sure you remove the t-stat when doing the flush, or you'll be stuck with a wholleee lot of water in the system [:@]
Edit: And it's the lower of the two hoses
Old Apr 23, 2008 | 06:10 AM
portcqb's Avatar
Im using unmixed coolant so can I leave the T-stat in and just dump in about 1.5 gallons of the unmixed?
Old Apr 23, 2008 | 09:26 AM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
I don't think you'll get an effective flush if you keep the thermostat in. It's designed to open at 195 degrees and your cold water from the hose will probably prevent it from getting to that temperature, so you'll be flushing through the water pump's bypass circuit (which it uses until the thermostat opens).
Old Apr 23, 2008 | 11:10 AM
WolfPack's Avatar
yea...take the thermostat out. If you're doing a flush, it's a good time to replace the t-stat anyway. They're like 6 bucks.
Old Apr 23, 2008 | 12:13 PM
portcqb's Avatar
Ok I will take the T-stat out should I get a delco or will a gates or stant work fine?
Old Apr 23, 2008 | 12:15 PM
Stant good, I'm sure the Delco and Gates are too. Just be sure you get one that's designed to stay open if it goes bad (used to be when they went bad, they stayed closed = overheating). I think all new Stants are that way now.
Old Apr 23, 2008 | 01:16 PM
portcqb's Avatar
OK I got a stant premium one I will do my flush in a week thanks everyone.
Chip
May 13, 2009 06:35 PM
oisinirish
Jan 30, 2009 05:35 PM
Xtremestreet
Jan 14, 2009 03:51 PM
jimbosv650
Jun 15, 2008 12:14 PM
XBlazer01
Sep 10, 2006 01:45 PM
