heater question
Old Apr 7, 2008 | 09:46 AM
walkingtall's Avatar
Banned
walkingtall is an unknown quantity at this point
Default heater question
hello I have a 98 chevy blazer and have a problem with the heat when I turn the dial to off a little bit of heat still comes out and I can hear something moving under the dash like something opening and closing. any ideas what that is. I have the automatic climate control.
Old Apr 7, 2008 | 11:37 AM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: heater question
how much air movement are you talking about..
you are hearing the hvac doors closing, pretty sure its normal for a little bit of heat to come out, not much though. mine does this also, i just put it to the cold setting and i can live with it.
Old Apr 7, 2008 | 11:43 AM
Banned
hey thanks for the info is it normal for them to open and close all the time even with the heat off.
Old Apr 7, 2008 | 11:45 AM
They should not be moving if you have the fan **** turned to the OFF position... Sounds like something is going wonky with your ECC module.
Old Apr 7, 2008 | 12:22 PM
cliro's Avatar
yeah, sorry I thought you meant it was just making the noise when you turned it off, not continuing to make noises while off.
Old Apr 7, 2008 | 02:39 PM
Banned
can you tell me where the ecc module is located, and is it pretty easy to fix. and is there another name for it I went to a auto website and can't find it no where on the site. I think I found it finally could it be called the air blend door actuator.
98blkblzr
Apr 12, 2007 03:05 PM
black19
Dec 26, 2006 09:18 PM
88s10Blazer
15
Dec 9, 2006 08:34 PM
celchlepp
Oct 31, 2006 01:19 AM
ericmiller5000
Dec 13, 2005 01:26 PM
