heater smelling like...
Old Dec 21, 2009 | 05:47 AM
DucatiKoenig's Avatar
DucatiKoenig is on a distinguished road
Default heater smelling like...
I'm not really sure how to explain this. But when i turn my heater on it has a burn kinda odd smell to it. I thought maybe it was the cabin filter but i found out blazers don't have those so now i'm kinda lost. Its only smells like that on heat and if i don't have the heat **** all the way over its not as bad. Kinda like its heating up something in the vents or something and making it smell kinda off.
i know this is a hard thing to explain but i hope i gave enough information; but if not ask.
Thanks in advance for any info.
Old Dec 21, 2009 | 06:31 AM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
does it smell sweet like antifreeze, does it fog up you windshield... its most likely your heater core that has went bad
Old Dec 21, 2009 | 06:37 AM
na no antifreeze smell at all. how do you check a heat core?
Old Dec 21, 2009 | 06:42 AM
Nvidia78's Avatar
most of the time if it is the heater core it will be sweet smelling and if bad enough in some cases the passenger floor board will be soaked.... does it smell like something electrical getting hot??... maybe there is something dead in the vents, like a mouse
Old Dec 21, 2009 | 06:48 AM
It could be signs that your blower motor resistor pack is about to blow. This is the only electrical components in the entire system that are supposed to get hot as part of their normal function. Air flow through the HVAC system is supposed to cool it, but over time, the resistors break down.
Do all of your fan speeds work?
Search for "blower+motor+resistor" and you should turn up quite a few threads on this topic.
Old Dec 21, 2009 | 07:38 AM
yeah all the speeds work. I just changed my varistor on the dash. the old one broke and it started to smoke. It went between 2 speeds and over heated switch.
but no water on the floor and def not a sweet smell.
Old Dec 21, 2009 | 07:41 AM
You might want to pull the resistor pack anyway and see if that may be the source of your smell.
Old Dec 21, 2009 | 08:01 AM
where is that located? I searched "blower+motor+resistor" but nothing really poped up.
Old Dec 21, 2009 | 08:05 AM
nj4x4blaze's Avatar
https://blazerforum.com/forum/showth...motor+resistor
Here's a thread that gives you an idea of it's location
Old Dec 21, 2009 | 08:12 AM
ahh i did read that one. my bad.
Is it easy to get too?
