Heater won't get hot.
Old Nov 30, 2012 | 07:05 PM
alanmead's Avatar
alanmead is on a distinguished road
Default Heater won't get hot.
99 LT model.
I have replaced some bad vaccume lines I found
that were bad. The system works on all the settings,
floor defrost etc. A/C blows cold, etc.
I am not convinced that I don't have a vaccume leak
somewhere. Doesn't seem like the flapper door that
moves to heat is working.
I was wondering if anyone has come across this problem in
the past and if there was a cure. Thanks in advance, Al.
Old Nov 30, 2012 | 07:27 PM
rockp2's Avatar
Old Nov 30, 2012 | 08:09 PM
warthogdriver's Avatar
Are you sure the lines running to the heater core itself are hot and circulating?
Cores can get plugged up on these trucks.
Old Nov 30, 2012 | 08:46 PM
alanmead's Avatar
I had not heard that.
I will be checking in the morning. Thank you.
Old Nov 30, 2012 | 08:50 PM
alanmead's Avatar
Great link. Thank you very much.
Old Dec 1, 2012 | 01:12 PM
alanmead's Avatar
Default Heat fixed.
So here's the scoop on this one.
I followed the directions from the link posted rockp2. Everthing seemed to be working as it should.
OK, what's next... Warthogdriver says it could be stopped up, hmm...
Removed the lines to the heater core and the large 3/4 line seemed dry. DO NOT use compressed air, lol. If you do, you will be blind for a few moments hunting fresh water.
Took the water hose and fushed one to the other, back and forth 6 or 8 times and replaced the lines. It worked! I didn't see a bunch of crud or calcium deposits come out, but I think there might have been an air bubble causing it to vapor lock possibly? It is blowing hot now.
Thanks for all the great advice guys, Al.
Old Dec 1, 2012 | 02:14 PM
rockp2's Avatar
Thanks for posting your fix for the rest of us that may come upon this problem.
Old Dec 1, 2012 | 04:06 PM
rriddle3's Avatar
This is usually the first thing to do when you are not getting heat.
Old Dec 1, 2012 | 06:02 PM
alanmead's Avatar
I figure if you use the forum to try to find
answers to problems, it should be common curtousy
to let folks know how you got things fixed.
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
Trip..
Oct 31, 2010 09:48 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
