hello everyone new to this site
Old 01-01-2013, 12:06 PM
Mcsiwi's Avatar
Mcsiwi is on a distinguished road
Default hello everyone new to this site
I am in need of help on my 01 Blazer 4x4 does not engage when dash buttons are pushed.
Mcsiwi
Old 01-01-2013, 12:44 PM
So what does it do? Details will determine how much assistance you receive. You can read through the Tech Articles on the subject to get ideas on where to start as well as what information to provide.
Old 01-01-2013, 01:18 PM
Mcsiwi's Avatar
thanks for the response. It does not make an difference what 4wd button that is pushed flashes for about 45 secs to a minute and returns to 2 wd. I can hear different clickes under passenger side dash boards an under the hood.
Old 01-01-2013, 02:39 PM
amp042's Avatar
amp042 is on a distinguished road
Maybe your actuator is not working properly?
Old 01-01-2013, 03:08 PM
3-button (NV233) or 4-button (NV236) switch in the dash? The diagnostic procedures can be quite a bit different. Use the transfer case designation to look through Tech Articles on the specific transfer cases to get things to try as MUCH of the steps to self diagnose 4wd problems are covered in detail in that section.
Old 01-02-2013, 08:17 AM
Mcsiwi's Avatar
it is a 4 button switch. where is the actuator located is it under the battery or on transfer case
Old 01-02-2013, 09:28 AM
Charles Hines's Avatar
Charles Hines is on a distinguished road
First thing to do is to inspect and clean all the connections on the TCCM located under the passenger kickpanel.That is the most common cause of problems as the wiring corrodes from moisture.Look for green powdery residue at the pins. The axle engagement vacuum servo is under the battery tray.The TCCM sends the power to the encoder motor on the transfer case.
Old 01-02-2013, 11:44 AM
Mcsiwi's Avatar
is the kick panel in the vehicle or under
Old 01-02-2013, 12:41 PM
m0perale's Avatar
m0perale is on a distinguished road
Inside, right where you'd kick it (front of the door). Mine got wet from people getting in after walking through snow (used to live in Michigan), and had to be replaced. What a silly design.
Old 01-02-2013, 09:05 PM
Mcsiwi's Avatar
thanks i guess panel has to come off but it is hopingly a cheap fix. will let everyone know if if and when it might work
Quick Reply: hello everyone new to this site
