help with bad vibration
Old Sep 28, 2009 | 08:41 PM
215stud's Avatar
215stud is an unknown quantity at this point
Default help with bad vibration
i have a 97 2 door 4x4 automatic i just got this back from my mom( i let her drive it for 2 years) and it starts shaking bad from 30 mph and on , it gets worst the faster you go. if i let off the gas it stops but as soon as i get back on the gas it starts again so, whats is bad im guessin it is eaither the torque converter, drive shaft, u-joints- or the rear end thanks for all your help
Old Sep 28, 2009 | 11:30 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
have you checked the tire balance? thats the first thing to check!
Old Sep 29, 2009 | 07:04 AM
215stud's Avatar
no i didnt think about tire size because it only does it when i hit the gas and quits when i let off
Old Sep 29, 2009 | 07:24 AM
Jason Rebellion's Avatar
Jason Rebellion is on a distinguished road
How are your motor mounts looking? Also check your U-joint on the drive shaft; does it do it if you put the trans in neutral and just race the engine?
Old Sep 29, 2009 | 07:28 AM
oktain's Avatar
It sounds like a U-Joint to me, but do the neutral test too. I had the same issue, it turned out to to be a U-joint, except mine was squeaking too.
Old Sep 29, 2009 | 08:00 AM
215stud's Avatar
thanks guys i had it in park and when i race the engine the motor does shake some but deff not it im off tomarrow so i will put 2 new u joints in
JPate
Feb 23, 2010 02:47 PM
coreroc
Jul 2, 2009 02:03 PM
GimmieBoost
Oct 9, 2008 06:15 PM
syrblitz19
Jun 17, 2006 09:13 AM
KA3AX
May 4, 2006 03:08 AM
